2020 "There's Always Another Sale™" (Report sales errors here.)
1…6970727475…100
  • Ditto. I'm having nothing but headaches from the MORE-AND-MORE coupon. I've tried all sorts of combinations of new items and Daz Originals, and can't get anything to work.
    edited February 2020
    More-and-more doesn't work properly for me.
    As you can see from the screenshots, the full 30 does not apply and some DOs still retain some value on them.
    This is happening while the total value of the cart does not discount for 30$.
    I am not sure what is happening.
    You have non Daz originals and too many items in your cart.
    Post edited by Wonderland on
  • alex86firealex86fire Posts: 1,130
    You have PC+ and new items in your cart...
    I know, but my problem is with the DOs that are not getting the full discount. 3RFD Suit and Mei Lin Morphs should go to $0.00 and they are not doing that.
    Are PC+ items supposed to make the coupon not work properly? Also, you need a new item for the coupon to be usable.
  • felisfelis Posts: 6,590
    My generel advice when using coupon codes, is to only add the qualifying items to your cart. Adding others seems to have a risk of affecting the calculation.
    Even with just the needed items, same problem.
    1395 x 629 - 137K
    1424 x 623 - 139K
    It looks like it did work in the second one. Surprising since you didn't even capitalize the code...
    you don't need to capitalize, I have never had a problem with that.
    The problem is not that it does not apply at all. The problem is that it does not apply for the full 30$ value. That was the case the first time around as well. It applies roughly 28$ although, you can see that it had more to discount as both 3RFD and Mei Lijn are not 0.00.
  • barbultbarbult Posts: 27,624
    You are correct and you have demonstrated the problem clearly. It is not taking $30 off. Here is another example of the same problem.
    1058 x 704 - 114K
    1057 x 702 - 114K
  • L'AdairL'Adair Posts: 9,479
    Try the cart without an item that is getting stacking discounts from today's offer.
    Nick Hair is both DO and OOT, so it's discounted more than the member's discount. It should work, but maybe the issue is the coupon is being applied before the addtional discount of being in a featured artist's store.
    I really don't know. I'm just guessing here.
    Post got duplicated??
    Post edited by barbult on
    You're right, it's $1.46 off. Not sure why. I never even bothered to add mine up because the extra I had to pay was just 4 cents.
    I thought about that but it would be nice if I could use the coupon on something other than items with only 30% discounts. This would be also what I have in common with barbult as he she also has an item that is in both categories.
    Post edited by alex86fire on
    I thought about that but it would be nice if I could use the coupon on something other than items with only 30% discounts. This would be also what I have in common with barbult as he also has an item that is in both categories.
    barbult is "she".
    barbult is "she".
    Sorry :), no idea why I assumed you are a "he".
    barbult is "she".
    "He" is the default pronoun.  No offense taken. It happens all the time. My name is Barb.
    barbult is "she".
    Nice to meet you :). I am Alex.
    Tried a new combination that discounts Nick Hair less.Still the same problem.
    I guess if noone comes online to report the problem before I go to sleep I will add something cheaper and buy like this. $28 free is still nice.
    1419 x 711 - 146K
    1443 x 708 - 147K
  • AtiAti Posts: 9,208
    Try three (or two) items that all cost roughly the same?
  • MORE-AND-MORE not working for me even though I have non-new and non-pc Daz originals. sad
  • Night Owl 3DNight Owl 3D Posts: 149
    MORE-AND-MORE was working for and then as I was checking it said not valid.  Same products it was working with earlier.
    Adding that "New Release" did the trick!
    Post edited by Night Owl 3D on
  • Coincidentally the $10 coupon still works for me.
  • StoicStoic Posts: 157
    @Stoic, Have you noticed the coupon offer today? It's the same as yesterday's but with new coupon codes…
    Copy and paste this code:
    OH-LOOK-MORE
    That will take up to $10 off qualifying items. You will find qualifying items here:
    https://www.daz3d.com/daz-originals#filter_platClub=0&filter_new=0&filtered=1
    (That link opens in a new window.)
    Thanks L'Adair & Thanks to all the wonderful folks at Daz for re-running this offer.
    I picked up Nightshift3D's Sci-fi Barriers and Walls.
    https://www.daz3d.com/sci-fi-barriers-and-walls
    Thanks again all.smiley
  • NorthOf45NorthOf45 Posts: 5,915
    MORE-AND-MORE is not working for me, but OH-LOOK-MORE does work.
    Did you also add a new release to the cart? It needs a new release to activate.
  • I suspect in at least some cases it's the way the offer is combining with other offers (one cart has a Fast Grab item, the other has some extra discounts - over the store page - applying even before the coupon is applied). If possible try without additional offers in effect; if not you can open a Sales Support ticket for the overcharge.
    I am sure it's an error in the order they calculate the discount and the coupon. If it was a normal offer where you buy something and you get x amount of "free" stuff I would have opened a ticket but since this is just some free stuff Daz has given us, I'm fine with what I got.
  • Both the Quarterly and Annual PC+ memberships show up on the pages linked to the Thank You banner but MORE-AND-MORE doesn't work for them. (Haven't tried OH-LOOK-MORE.) I understand if the memberships aren't meant to be in the promo, but they should be removed in that case.
    1920 x 1080 - 393K
    1920 x 1080 - 337K
    I need more sleep...
    They should, but at least they removed New and PC+, which is a huge step forward for Daz in accurate advertising.
    I'm not sure how they could filter products out of results for a vendor's store on a product-by-product basis. Daz Originals have their own vendor store, and the link from this offer goes to that store using global filters to prevent new releases and PC+ products from showing in what amounts to search results on a vendor's name. (Those same filters will work for any of the vendors' stores.)
    It would be nice, though.
  • I wrongly assumed yesterday's Daz site issues were due to ...maybe...perhaps..possibly the release of Genesis 9. Oh well...
