Post Your Renders like it's the year 2020!!!
194969899100
    Joanght said:
    I made a quick low baked London cobble brick pathway 72inx32in (Object files). The .Car document is 115 mb large. I had some difficulties uploading 117mb. Some of the screenshots here will show the baked displacement map onto the object. There are no texture maps to any of the objects, the shadows casting upon the now 3d geometrics is what gives it's depth.
    I kept the displacement level low to reduce the amount of file size.
    Each brick would have had the original file size of 407mb, I reduced it down to 12mb per brick.
    407mb baked object has alot more detail quality than the 12mb brick , however far away the details are negligible.
    omg  much much better than a bumpp map.  muy bien
  • My first animation with “PyCloid”
    kewl!
  • My second & third animation with “PyCloid”
    thanos snap?wink
  • DiomedeDiomede Posts: 15,454
    An attempt at using Carrara's native NPR renderer
  • magaremotomagaremoto Posts: 1,238
    edited March 2020
    test on haze dome hue, intensity and density, and how it affects general lighting
    3840 x 1777 - 1M
    3840 x 1777 - 1M
    3840 x 1777 - 1M
    3840 x 1777 - 1M
    Post edited by magaremoto on
    looks good!
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,433
    edited March 2020
    Carrara rendered video with a bit of that other software at the end
    Carrara also rendered the dynamic fur like a champ,
    yeah did use Octane plugin but still
    DAZ studio 3Delight crashed on the LAMH animation sync after 30 frames and I found out 4 hours later after leaving it at frame 28 hence the looped prance
  • StezzaStezza Posts: 9,193
    edited March 2020
    very cool Wendy, I think @Headwax could use that cat to catch some of his rats! laugh
    I modeled a house yesterday... with toilet paper .. as you do do.... well it is 2020 angel
    800 x 667 - 805K
    Post edited by Stezza on
  • Love the humour! Does the main character rub his bottom along the floor like dogs do when her done do do'ing?
    that is a dog anal gland thing
    I believe you are supposed to help them by manually expressing them with your fingers blush
    the door opens!!yes
    Great tip house, Stezza!
    yep, the door is a swinger laugh
    all these new slang words I'm seeing this morning... always learning but have no idea what a tip house is but thanks wink
    I think tip is what happens when I try to type tp for toilet paper, but screw it up.
    aha... an ebil twist wink   devil
    edited March 2020
    w.i.p. testing Philemo's PBR lighting model (road, foliage, metals)
    5760 x 2665 - 2M
  • test on haze dome hue, intensity and density, and how it affects general lighting
    Great experiments - I like the heightened contrast of image one and the colour of image four - it doesn't have the blue shift of the other three!
  • w.i.p. testing Philemo's PBR lighting model (road, foliage, metals)
    Once again, a great image - have you thought of adding 'translucency to the leaves and sheets spanning the buildings - I know this will add to the render time, but it seems to me that you are looking for greater levels of 'reality?'
    edited March 2020
    thx Mystiarra and FENgari :)
    still learning Philemo's PBR shader addon but it seems translucency doesn't work properly whereas PBR sss looks good
    here another try with PBR sss applied on foliage and sunshades, plus some adjustments
    edited March 2020
    double post
    7680 x 3554 - 4M
    chesterhaven
    2 hours on a hexacore.
    1280 x 720 - 919K
  • UnifiedBrainUnifiedBrain Posts: 3,588
    It looks nice.  But two hours seems way too long, especially on a hexenbeast.
    Why do you think it took so long?  If you don't mind me asking, what were your render settings?
    i turned on ambient occlusion. and auntie alias on good. prolly what did it
    after all that, not happy with bell tower.
    thinkin a job for the lathing toolsmiley
  • ..“Translucency” - how good is it?
    edited March 2020
    updated video
  • 0oseven0oseven Posts: 626
    I got the Quixel Mixer but just have not had time to explore.
    Free at the moment
    https://quixel.com/mixer
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    edited March 2020
    A render based on the theory that COVID-19 was caused by Chinese people eating raw pangolin scales to fight impotence.
    Even if it's not true, pangolins are the most poached specie in the world for the impotence thing in traditional Chinese medicine.
    1920 x 1280 - 697K
    Post edited by Philemo_Carrara on
    eat raw?
