Problema de Memoria / Memory Problem
EN ESPAÑOL
Tengo un PC con 250 GB de memória de los cuales más de 200 están usados en cosas de DAZ. ¿Como puedo hacer para pasar las cosas a otro disco (disco duro externo por ejemplo) sin que se resienta lo que tengo en DAZ?
IN ENGLISH
I have a PC with 250 GB which over 200 are used in DAZ stuff. How can I move things to another disk (external hard drive for example) without hurting what I have in DAZ?
  • plarffplarff Posts: 287
    If i understand you correctly you want to move your DAZ assets you buy at the store to go to another HDD and not on you C-Windows installe drive.
    You can do this.. In the DAZ Edit/Preferences/Content/Content Directory Manager/
    Add in the DAZ Connect Data and DAZ Studio Formats path to go to your new HDD location. Portable or internal drive.
    In you DIMS (daz install manager) in the Advanced settings change also the path to reflect to your HDD you now installing your newly bought assets..
    If that is what you are after...
