RRRR But you promised voting thread
TotteTotte Posts: 14,913
Hey, you there, yes you, come closer, I got something to show you. Look, you can vote in the RRRR But you promised render contest, and have some fun while doing it. Just refrain from beverages while voting, the RRRR takes no responsibility for beverages ejected onto the keyboard due to laughing reflexes.
Enties are here: https://www.daz3d.com/forums/discussion/374101/rrrr-but-you-promised-entries-only-thread
Vote here: https://www.surveymonkey.com/r/XCPF93Z
And comment in the thread that you have voted.
So, what are we voting about?
Winner in each category
- 1 item from Totte's (Code 66)'s store (no DOs or Bundles)
The voting starts now, and ends Sunday March 8 2020 - at 23:59:59 local DAZ Time
How votes are tallied and summed up:
Voting points: 1st = 5 points, 2nd = 4 points, 3rd = 3 Points, 4th = 2 Points and Tiebreaker = 1 Point.
If an image gets 1st, two 2nd, one 4th and two tiebreakers in a category, that is 5 + 2x4 + 2 + 2x1 = 17 Points
Every image points per category is summed up, and top three is calcutaled in each category. As we now have five prizes, a maximum of two entries from the same artist can end up top three in each category, this is to spead the joy a little more.
The image with most points from the same artist will be the base, the the average score for up to for other images will be added to that score, but if that image takes a top three placement, images who got to the cream of the crop with help from other entires, will gain extra LBs based on how many places it climbed, minus one. Here are two examples:
Example 1: The top image from X has 15 points. X also has five other images that has been voted for, 10, 8, 7, 7 & 5 points. Thaking the average of the first four images behind the top one is 10+8+7+7 = 8, so the first image which was at 4th place, now gets 23 points and rises to the top and becomes the winner. But, that image climbed 3 steps, so it will not only win, but give the winner 3 LB for the next run.
Example 2: The top image by Y has 11 points, and the second image 9 points. The top image will now have 20 points and go from 5th place to 3rd place, granting Y 2 LB for the next run.
If two images ends up with the same score, we use the same rules as in the European Song Contest, the number of higher scores wins over many lower scores, so if one image has 5+5+5+1 (16) and another has 2+2+4+4+2 (16) the first one will come before.
To avoid votespamming, anyone voting needs to post here in this thead that they did vote, and use the same name as they have posting here as the DAZ Forum name in the first question in the vote system at SurveyMonkey.
Remember to vote in both categories and place all five votes in both categories. Votes that fail to vote in both categories and votes faling to vote 4th to 5th place will be discarded.
