breasts
efron_24
When breasts are pushed against a surface.. they flatten (a bit) ... I see examples with DAZ3D where that is done with G8 ladies..
But how to do it ? I do have Breastcorntrol for G8, and it seems to be possible with that.. but i can not find out how to activate the morph
Since you have Breast Control Genesis 8 Female(s), what you need to do is select the figure, then on the Posing tab drill down to Chest > Breast Control, and you'll see all the posing morphs there. The one you need is called something like "impact front".
thanks ... I am going to search for it
You can also apply a smoothing modifier to the figure and have the surface the collision target. Reduce either the collison iterations or smoothing interations to 1 or 2 and you can get some pretty good results. I do it frequently for a little squish when people are sitting on a hard surface (or use it on a soft surface for a little indent). The trick really is putting one of them to 1 or 2 so the indent isnt huge.
that is way to technical for me... smoothing modifier ? iterations... ? That is a bit too much.. but thanks
It worked.. thanks
In previous figure generations, products have been made that enable 'squish' morphs that specifically address this need. These usually include butt squishing morphs as well for sitting figures, etc.
I don't know if any PAs have released such a package for G8F, but others in the forums might be able to recommend options if they exist.
--ms
