Where are instructions for Ultimate Iray Skin Manager
wildbillnash
in New Users
A while back I purchased the Ultimate Iray Skin Manager and today I tried to figure out how to use it. But I can't find it anywhere. And the instructions are hidden as well. Can't figure out where they put it and the site is no help. Anyone know where I can find them? There's not tab visible for it and I can't find it under 'Panes'.
There is a pdf documentation which you can find through the ReadMe here: http://docs.daz3d.com/doku.php/public/read_me/index/50989/start (under Additional Details)
The script to run should be in Smart Content under "Utilities - Scripts"
Thanks for the info but, nope, it's not in the "Utilities" section and the info I've read so far on the pdf file only talks about using it, not where to find it. Any other place you can think of where it could be hiding?
Okay, I should have scrolled down farther below the link to the pdf file. Found where it's located in the Content Library, just not in the Smart Content section. Thanks again.
Okay, got creative and found it in the Content Library, once I knew what I was looking for. (I need new glasses).
OK, sounds like there might be a bug in the metadata, but at least you got there!
