Reducing Light of the Umbrella
Hi! I wanna make a Photo, where a girls jumps in water with her umbrella, but ... the umbrella acts like its a light source.
I did turned the light panel from left to right, but it is still the same.
Any advice?
  • MattymanxMattymanx Posts: 7,000
    Turn off Translucency and set Thin Walled to ON.
  • LoonyLoony Posts: 1,817
    edited February 2020
    Thanks, I will try it.
    btw. inspired by this:
    https://www.daz3d.com/april-rain-undergarments-for-genesis-3-female-s
    Post edited by Chohole on
    I tested it, thin wallet will make it transparency and thats not my target, thats why I did dye it self, because the basic shader was like that.
    So if I let it full pink it will always reflect?
  • A light, shiny object will inevitably reflect soem light onto other things. If it has an inner and an outer surface (or if you have the double-sided Iray shader from the store) you could make the inside dark to reduce that effect. One thing to check is the the surface of the umbrella doesn't have a non-black Emission Colour property.
    the inside dark thing sounds interesting, but I dont think I have such double sided layer thing...
  • Yes you do, a geometry shell with a -ve offset, then set it's material properties.
