Render size in Urban Future 7
Hello,
I just bought Urban Future 7. Now I have problems to change the render size. No matter what I try it still renders the size from the included settings.
I need to render small sizes for preview, but the render size is 4096 x 1700.
Is there a setting that could be locked, so I can not change it? I never had this problem before
  • LeanaLeana Posts: 12,884
    Have you checked the parameters for the camera? IIRC it's possible to set the render dimensions there.
  • LindseyLindsey Posts: 2,009
    edited February 2020
    This should work to change the render size to the Active Viewport:  Render Settings> General> Active Viewport
    Edit: I take this back as it didn't work when I tried again.  Easiest is to create a NEW CAMERA (Create>New Camera and select the "Apply Default Settings) and select the new camera.
    Post edited by Lindsey on
    I'm so stupid...this is of course the easiest way! Hahaha! Thank you so much!
    Thank you for this tip! This is a great and simple way when I have problems again!
