Render size in Urban Future 7
FantastArt
Hello,
I just bought Urban Future 7. Now I have problems to change the render size. No matter what I try it still renders the size from the included settings.
I need to render small sizes for preview, but the render size is 4096 x 1700.
Is there a setting that could be locked, so I can not change it? I never had this problem before
Have you checked the parameters for the camera? IIRC it's possible to set the render dimensions there.
This should work to change the render size to the Active Viewport: Render Settings> General> Active Viewport
Edit: I take this back as it didn't work when I tried again. Easiest is to create a NEW CAMERA (Create>New Camera and select the "Apply Default Settings) and select the new camera.
