G8F School Girl Costume material zones?
Hi -
Would anyone happen to know if Pretty 3D's School Girl Costume's top/shirt has separate material/opacity zones for the sleeves. I had a texture idea for it, but don't want to make a pricey mistake if it won't work.
Thank you.
  • I don't know, but...
    (a) If it doesn't, you can probably add them in for yourself using the geometry editor
    (b) If that doesn't work out for you, you can always return the product and get your money back.
    I keep forgetting about the geometry editor, but have no idea how to use it. Guess I should play with it. Meantime, maybe someone else will know.
    Thank you, though.
    Thank you, though.
    It's pretty easy to use, select the item, then enable the geometry editor and select the polys you want to affect. Then create a new material zone from those polys. You can also hide and delete polys
  • jardinejardine Posts: 1,223
    separate material zones are nice, though.
    geometry editor's selection capabilities can be a little frustrating sometimes.
    j
  • Checking...
    No, no seperate material zones for the sleeves, just a Base zone for the whole shirt.  Sorry.
  • Checking...
    Thank you!
