Product installed but not in SMART CONTENT - sort of
davesodaveso Posts: 8,227
PRO-Studio HDR Lighting System 3
https://www.daz3d.com/pro-studio-hdr-lighting-system-3
I have the entire set, 1-3. 1 and 2 show up in LIGHTS in smart content. 3 does not.
When I search ALL PRODUCTS, it shows up but I cannot figure out where it is exactly. It does show up in CONTENT LIBRARY
OH ... I found all 3 in RENDER-SETTINGS ....
HOW DO I GET A COPY INTO LIGHTS? I would like all 3 in the LIGHTS category in smart content.
TIA
  • Right-click on the files>Categorise and add tho the desired category in Lights.
  • davesodaveso Posts: 8,227
    thanks ..I'm not sure where I'm to do this from. I dont see Files - categorise
  • LeanaLeana Posts: 13,475
    edited February 2020
    It's not a "files" menu, you right-click on the actual item in the library.
    Post edited by Leana on
    in the content library or smart content. i tried both actually and nothing about categorize.
  • nemesis10nemesis10 Posts: 3,992
    A right-click gives me this:
    687 x 514 - 93K
    Post edited by nemesis10 on
    i see... for an individual piece of a package, not the entire package. So the light deal I'm wanting to move from Render-Settings to Lights, I would have to do each of 50 files?
    Or maybe i can move it within the file structure?
  • Richard HaseltineRichard Haseltine Posts: 111,202
    Assuming you are looking at the Products tab of Smart content, a product will appear in any category to which at least one of its files belongs. If you want to assign all the files then you can do that through the Edit Product Metadata dialogue, which you can launch from a right-click on the product in the Content Library
    thanks..i'm totally lost there. will leave it where it is i guess. thos metadata stuff is way out of my knowledge.
  • NorthOf45NorthOf45 Posts: 5,877
    Well, you can do more than one file at a time, if they are in the same folder. Better yet, go to the Products view (the Alphabetically grouped list) and go to the product in question. ALL items will be in that folder, so you can select the ones you want to categorize the same way and do them all at once. If you want to remove them from a category, deselect the categories you want to remove them from at the same time.
