HD Body Shapes for Genesis 8 Female Problem
I purchased the new product called HD Body Shapes for Genesis 8 Female which adds 5 new HD morph dials, but I can't get them to show up. I first installed with Daz Connect and then tried a manual zip. The product shows as installed, but it's only containing files in the /data folder and there are no library facing files to be found. I don't see the morphs appearing for my G8F so I'm wondering if they are using different names than what the product page says (Athletic, Bold, Casual, Curvy & Slim) and I tried based on the file names under /data.
Am I doing something wrong?
Yes you're doing fine. Morph dials show up normally on the Shaping Panel, sometimes also on the Parameters Panel. Look under 'body' ... or type one of the 5 words in the search box ... something should appear.
Thanks for the help. I looked under Parameters/Shaping/Hidden properties, and still nothing but then I thought there may be a problem loading the morphs and the Log reveals:
Probably an issue with the product? Should I file a bug report somewhere?
Also having this problem. Can we expect an update or refund soon for this non-functioning product?
Sorry, I missed this - it sounds like a fle that eithr failed to decrypt after download or possibly a file that is corrupt on the servers. Are the thumbnails for any presets readable? If not then I would suspect it's the decryption issue - you could, for now, uninstall the Connect version and install through DIM (or take the contents of the Content folder from DIM and place them in the /My Daz Connect Library/data/cloud/1_63425/ folder)
Hmm, I'd forgotten I'd purchased this set - my log show the same (which doesn't preclude its being decryption issue) - all the fiels are unreadable. I just copied the Data and Runtime folders from the DIM Zip's Content folder into the /My Daz Connect Library/data/cloud/1_63425/ folder and it seems OK - no errors (for that set) in the log, the plain text metadata files are readable in a text editor.
