Help required please with DP Teen Jayden 6 Carrara Shaders, UPDATED....HELP ANSWERED....BUT still c
Musicplayer
Hi Folks,
Could somebody please explain to me, as I am a newbie with regards to using shaders, how to use these shaders. I have loaded Jayden 6 into my scene and removed the current shaders and replaced them each time with one of the three option set of shaders in this pack, only to find that the character remains looking exactly the same in each render.
I bought this product because it appears to show 3 different appearences for Jayden 6 depending on which shader group is used. Clearly I am doing something very wrong, and have failed to find any guidelines within Cararra tutorial Youtube videos. So I am hoping someone can come to my rescue. :red:
Many thanks.
http://www.daz3d.com/new-releases/dp-teen-jayden-6-carrara-shaders
Ringo has a tread about these shaders, maybe ask there, as he is pretty likely to see the question.
http://www.daz3d.com/forums/discussion/35987/
Thank you for your prompt reply evilproducer, I was unaware of his thread so will post a link there too regarding my question. Cheers :-)
I would offer my help if I could, but I'm using C7.2 Pro for the foreseeable future, so no Genesis for me. For now.
Please take a look at the attached screen capture. It explains how to apply the shader presets.
The main difference between the shaders are the eye colors. The skin color remains the same.
Thank You for your support.
Regards
Many thanks RingoMonfort for your reply, and I now understand how to apply these shaders.
I must admit I still remain very confused by the products description that says:- quote.... "DP Teen Jayden 6 Carrara Shaders is a set that comes with 3 stunning skin shaders".
The description then goes on to say:- quote.... "◦3 Skin Shaders and Eye Colors"
I have noticed the change of eye colour, but as you say in your reply:- quote.... "The main difference between the shaders are the eye colors. The skin color remains the same".
So what is the products description referring to when it says SKIN shaders, if only the eye colours are affected by these shaders ?
Also the promo pictures skins appear different, but this may only be the lighting and angle. However, if only eyes are changed why do some of the promo pictures show Jayden's body, and not just facial images.
Am I still missing something here....is the products description confusing as to what these shaders actually do, or just my misunderstanding ?
