Moving Hair Post-Sim
What techniques can I use to move hair post sim? I have some fly awyas I'd like to move out od sight
Thanks
Thanks
I had the same problem and found 2 Solutions which worked for me.
Variant 1:
Select the irritating geometry and create a new surface from the selection. Then set the surface's material opacity to 0. Shoud do the trick.
Variant 2:
Use a dFormer to move the portion of the hair. To do so you most likely have to use a weight influence map instead of the automatically created spherical field.
