When loading daz figure into carrara, where is parameters?
huhuthuhut Posts: 0
edited January 2014 in Carrara Discussion
Hello?
I just started to learn carrara.
I am using carrara 8.5 pro.
I use this tutorial for study ---> http://www.infiniteskills.com/
anyway,
I loaded a v4 in carrara like first attached picture.
in general tab, there is no parameters.
but in the tutorial of infiniteskills, there is parameters in general tab like second attached picture.
Did I do something wrong?
Becuase there are no parameters, I cannot load morphs and adjust them.
Post edited by huhut on
  • DUDUDUDU Posts: 1,945
    If you load Morph Inj, you should have parameters...
  • huhuthuhut Posts: 0
    when I load morphs, it is same to me... no parameters appear..
  • DartanbeckDartanbeck Posts: 22,134
    edited January 2014
    Look at your top image.
    They're in the "Parameters" tab, just above the "General" tab that you're viewing - right side panel toward the top.
    535 x 508 - 217K
    Post edited by Dartanbeck on
    edited January 2014
    If you load "inj creature", select the head and look if you have parameters.
    Post edited by DUDU on
    Right! There are parameters tab beside general tab.
    Thank you for the answer!
    Oh, it's new in c8.5 !
    You're welcome! ;)
    This tab not being there makes using earlier version a real PITA for me now. Same with the new zeroing features in the Animation menu in the top menu items.
    Yeah, I love the new Parameters tab. Note the top drop-down button in the tab. It contains all of the sorting features to only display the dials you need to see.
    Do keep in mind, however, that in order to find the morphs on a Prop object, you need to be in the General tab. The reason being that these objects are not rigged, so they show a different interface.
