clothing won't import
Hi.. I downloaded DAZStudio 4.6 yesterday and have managed to 'download and install' one set of clothing that I bought.. Now.. the problem is that I have a second set 'Princess of Asia' and for some reason it just doesn't want to work.. although the 'materials' on the right hand side are there. I am clicking on the 'download and install' button and have tried a couple of times.
Any suggestions as to where I am going wrong?
I would need a bit more information to help you
Is this inside the DIM (DAZ Install Manager) that you are clicking?
I'm not clear if it is failing to download and install files, or if it is failing to load clothing when you double-click the files in DS. If the latter, materials are settings - you need to load the clothing model first, then apply the materials with it selected; the clothing figures should be in the folder that holds the Materials folder if you are looking in the Content Library pane.
Thank you JimmyC and Richard, but I've managed to get it working. :)
