clothing won't import
chaylastormchaylastorm Posts: 16
Hi.. I downloaded DAZStudio 4.6 yesterday and have managed to 'download and install' one set of clothing that I bought.. Now.. the problem is that I have a second set 'Princess of Asia' and for some reason it just doesn't want to work.. although the 'materials' on the right hand side are there. I am clicking on the 'download and install' button and have tried a couple of times.
Any suggestions as to where I am going wrong?
    I would need a bit more information to help you
    I am clicking on the ‘download and install’ button and have tried a couple of times.
    Is this inside the DIM (DAZ Install Manager) that you are clicking?
  • Richard HaseltineRichard Haseltine Posts: 110,513
    I'm not clear if it is failing to download and install files, or if it is failing to load clothing when you double-click the files in DS. If the latter, materials are settings - you need to load the clothing model first, then apply the materials with it selected; the clothing figures should be in the folder that holds the Materials folder if you are looking in the Content Library pane.
  • chaylastormchaylastorm Posts: 16
    Thank you JimmyC and Richard, but I've managed to get it working. :)
