Translation parameters missing from child figure
Hi all,
I need help with the following problem (I have attached two images to try to illustrate what's going on):
In my Scene there's a figure named "Button" which is made up of a cube (named "Cube") for the base, and a cylinder (named "Cylinder") for the actual button.
The cube is the cylinder's parent, so that I can move the base and the button at the same time, but I would like to be able to "press" the button, i.e. have it move up and down relative to the base.
The problem is that when I want to edit the button's parameters, I can only see Rotation and Scale. The Translation parameter is missing... and it's driving me insane!
How can I make the Translation parameter appear in the list of parameters for the button?
Any help is much appreciated!
- Ari
  • In the Parameter pane option menu (the lined button in the top corner, or right-click the tab) enable Show Hidden and then you can find the translations sliders, click the gear icon on the slider and select Parameter Settings, and turn off Hidden.
  • Thank you so much! That solved the problem! yes
