Translation parameters missing from child figure
Hi all,
I need help with the following problem (I have attached two images to try to illustrate what's going on):
In my Scene there's a figure named "Button" which is made up of a cube (named "Cube") for the base, and a cylinder (named "Cylinder") for the actual button.
The cube is the cylinder's parent, so that I can move the base and the button at the same time, but I would like to be able to "press" the button, i.e. have it move up and down relative to the base.
The problem is that when I want to edit the button's parameters, I can only see Rotation and Scale. The Translation parameter is missing... and it's driving me insane!
How can I make the Translation parameter appear in the list of parameters for the button?
Any help is much appreciated!
- Ari
In the Parameter pane option menu (the lined button in the top corner, or right-click the tab) enable Show Hidden and then you can find the translations sliders, click the gear icon on the slider and select Parameter Settings, and turn off Hidden.
Thank you so much! That solved the problem!
