Cararra Sound Clips
bdproductionsbdproductions Posts: 45
I am attempting to use a sound clip to act as a guide for animating a laugh sequence. I used basic math to get the animation close, but I need to determine the milliseconds to fine tune it.The sound plays choppy or loops the first few seconds (or milliseconds). The loop animation button is not selected and the file is only two seconds long. I've checked my Cararra 8 manual as well as other forums for an answer with no luck. If this feature has no real purpose, why include it as a feature at all!?!
  • bdproductionsbdproductions Posts: 45
    Never mind... I've found another way to deal with the problem.
  • DartanbeckDartanbeck Posts: 22,154
    Never mind... I've found another way to deal with the problem.How did you get it to work?
    I didn't in Cararra... I used Sony Sound Forge. I created markers in Sound Forge to track and measure the timing of the laughs, wrote the markers down, then used the info in Cararra.
    Part of the issue may be due to the quality of the sound clip. I don't use it that much, but I when I do, I use a lower bit rate as I put the real audio in when I edit the video. The imported audio in Carrara, as you were trying to do, is really meant as an animation guide for lipsync and such.
    Part of the issue may be due to the quality of the sound clip. I don't use it that much, but I when I do, I use a lower bit rate as I put the real audio in when I edit the video. The imported audio in Carrara, as you were trying to do, is really meant as an animation guide for lipsync and such.[/quote
    The bitrate of the clip may very well be the issue. I have never used the sound clip feature in Cararra. I also add my sound in during post production. When saving MP3's, it is possible to lower the bitrate of the sound file (Cararra doesn't support MP3 format). The wav format only has three possible quality selections (in Sony Sound Forge and the rest of the packages I use) , and all of those bitrate samples are rather high in quality. At any rate, I've found a solution. Thanks anyway.
  • DUDUDUDU Posts: 1,945
    I tried once to import a 16 bits/48Khz (wav),Carrara did n't want it.
    I then imported a wav 16 bits/44,1Khz and it was OK.
    (It was for a test with Pycarrara)…
    Thanks DuDu, I'll give that a try. Being able to import the sound while working definitely saves time!
    DUDU_00001, your suggestion was correct. However, I had to create a mono track of the sound clip. I didn't even have to reduce the sound quality. So maybe the problem with importing sound is that clip, in my case, needs to be a mono wav file. Thanks again for pointing me in the right direction!
    Glad to see some more posts from you. I'm also glad that you seem to be having success using Carrara.
    I have a Home Studio to compose my music with Cubase and it is very easy to mix two stereo channels into only one mono.
    I am almost sure that “Audacity” (free) can do it too.
