2020 "There's Always Another Sale™" (Report sales errors here.)
12930323435100
  • Cris PalominoCris Palomino Posts: 12,556
    Ok, so no new item needed. The items are straight discounted. What you see is the discount you get on those featured stores. Text should change in a bit.
  • alex86firealex86fire Posts: 1,130
    Ok, thanks for clearing it up.
    Can anyone also explain to me why there is a limit of one gift card per customer every time we have an offer on them?
    You could always buy a bigger gift card from the start if you wanted. Or if you purchased a smaller one and you realise you want more, you could always make a new account and sent a gift card to your main account using the offer. So why the limitation?
    That would be something only customer service could answer.
  • This item does not show a required product, while it clearly is a texture pack: https://www.daz3d.com/bloodoath-textures
    This is a File a Support Ticket issue.
  • SylvanSylvan Posts: 2,719
    edited January 2020
    The HA-HA-STAYIN-A-FIVE code won't work for me. I've got Do's in my cart and am not using new items. I also tried to alter the amount of products, but it also won't work on one item.
    EDIT
    Oh wait, I already used another of those coupons. So I guess I can only use ONE of them, right? Since it's called "pick the sale you want"?
    Post edited by Sylvan on
  • MunemanMuneman Posts: 221
    It's worth noting that the coupons don't exclude Fast Grabs and there's several Daz Originals in that selection.
  • LeanaLeana Posts: 12,811
    Several people have used more than one of the coupons, so it shouldn't be that. Can you post what you had in your cart?
  • tsroemitsroemi Posts: 3,509
    Hi there, this coupon is not working for me, either. I‘ve tried with this item - https://www.daz3d.com/vintage-rose-for-genesis-2-females - that is on the DAZ Originals list. Before, I‘d already used the Mikey-Likey coupon. So maybe it is correct that we can use only one coupon? A note or something to this effect would have been helpful then ...
  • AtiAti Posts: 9,185
    This is a PC+ item. The coupon excludes PC+ items.
    What the?! I tried again and now it is working Oo odd, but yay!
    Oh my, I also figured this out just now - sorry for being such a doofus ...
    HA-HA-STAYIN-A-FIVE coupie not working on Rynne 8  base??
  • GordigGordig Posts: 10,613
    That coupon excludes new.
    oh she still new?
    thanks.
    Maaaaaaaan, that puts me in a bind. I try not to buy pro bundle items outside of the pro bundle, but most of the items I really want out of Gabriela's pro bundle, including Gabi herself, are in Fast Grab right now. So do I buy those items, plus the HD add-on and a related dress that's not in the bundle, for $25.73 now? Or do I hold out for the pro bundle, whenever that gets cheap enough for me to pull the trigger?
    Well, the items are all in my cart right now, so.......
  • nonesuch00nonesuch00 Posts: 18,765
    I used 3 of the coupons (EYE-OF-NEWT, DECK-OF-CARDS, FASTEST-ONE-IN-THE-WEST) so you definately aren't limited to one of the coupons. Make sure you read the fine print though. For example, I wanted the Auto Face Enhancer Bundle using the EYE-Of-NEWT but for that couple bundles are disallowed. Instead I only bought the main product in that bundle with that coupon.
    Also, if you intend on maximizing the number of products and discount you get on all of them, pre-plan your shopping carts for all the coupons, apply the discount for each coupon's shopping cart, add those shopping cart's monetary totals together, and than buy a gift card for 75% of that total value. It's a bit of work but if you're on a tight budget worth it.
  • DaventakiDaventaki Posts: 1,624
    So I messed up and forgot to add my free $10 Daz Original to the cart when I bought CJ Pro and Fantasy bundle.   Can I submit at ticket and just let them know what item I want?
    any chance rynne will come out of new status before the coupies expire?
  • GalaxyGalaxy Posts: 562
    edited January 2020
    MIKEY-LIKEY there are more than 2400 items but this coupon only supports 10. It would be better if it support at least 100 items.
    Post edited by Chohole on
    Yes, it's worth opening a ticket.
    Not a chance. Items are new for 60 days and Rynne was released on December 17th.
    Yes, just choose the correct drop down for the ticket problem when you write a ticket for the store credit/DO $10 freebie you want.
  • junkjunk Posts: 1,491
    Does anyone know if you have to own CJ 8 to use the "CJ 8 Fantasy Bundle"?  It sounds like a funny question but it does not specifically say "CJ 8" is required for the product under required or under the description.
  • TorquinoxTorquinox Posts: 4,352
    edited January 2020
    Hair, outfits and poses should be fine with any G8 female. The character morphs likely look weird without CJ. The skin should be transferrable to any ordinary G8 female unless CJ has unique UV mapping.
    Post edited by Torquinox on
    Thank you Torquinox. I figured the same things but just thought it odd that they didn't make CJ 8 a required product
    For a bundle you need to look at the requirements on each item, not directly on the bundle, as all parts won't have the same required items.
    the new release code  THIRTY-HARRY  doesn't work on Rynn 8?
    edited January 2020
    That's not the code for new releases, that's the one for non-DO content.
    The one for new releases is EYE-OF-NEWT
    Post edited by Leana on
    She not working with this sale
    Buy any New Release to get 60% OFF Daz Originals  i
    thanks !
    I don't know what sale that is supposed to be, but those kind of offers usually don't give you a discount on new items.
