Pattern Hair for Genesis 3 and 8 problem
Pattern Hair on G8F has also in the shortest hair length single long hairs.
I found no parameter to handle this. Is there any solution (and perhaps reason for it)?
  • scorpioscorpio Posts: 8,534
    I'm not seeing this, have you used the preset to remove the 'top hair'?
  • chromchrom Posts: 261
    smiley thank you very much - that's the solution
    I only adjusted lengths to minimum
    Good glad you got it sorted.
