Puppeteer- Editing And Speed Questions SOLVED
Novica
Post edited.
How do you name the layers/create different ones?
How do you eliminate the timeline and redo it?
Is the speed at which you scrub the speed you are stuck with? When I changed the frames per second, I didn't see a speed up. Would that be a limitation of my computer, or does the FPS not do what I thought it did?
Found the answers on my own.
Post edited by Novica on
Please, what was the answer?
I was intending to share :) but I share a thread and a lot of folks pitch in over there, so when we explore different things we help out in that centralized location. Here ya go! I do need an answer on how to save a puppeteer animation once it's done- I need to get it in AVI format.
http://www.daz3d.com/forums/discussion/34269/P855/#528043
In which software ?
To speed up the frames, I found a post in a different thread about using Virtual Dub. Jaderail (over in my thread) really likes it but says it does not need to be AVI files. I'm so new to this that it isn't funny- I have my timeline the way I want it, don't have a clue what to do so far as saving it. Jaderail just posted that V.Dub doesn't have to be an AVI a few minutes ago. So I don't know anything about DUFs and animations- going to go read up on V.Dub. Arrrgh. :)
Well, I did find in the render settings that you choose Render To and the choice of movie is there and it is AVI.
If you Render to AVI any Error in your File or small hic up on your PC will error the AVI file making it useless. Most of us that Animate with DAZ Studio do Render to Frames just to avoid possible Render or File errors. We then use a Editor to assemble the frames to a File for saving.
The SAVE method in DAZ Studio only matters to you as the user in DAZ Studio. It does not matter one bit to a Video editor like VeeDub once you have your animation file or frames to use.
What is a good size pixel-wise for the animations? I know the forums max is 2000 x 2000, would that cause a huge file size?
Is that the same as render to "Image Series?" (When you say render to frames.) Assuming that would be the same.
I just got an error message that said "Error saving the file." Then it says on the next line "The render could not be saved." Then try again or choose a new file name. It had png automatically selected, should I have done a different type file? Frame 1 was at 23% when it happened.
Do not add a Number to the File name DS will auto do that for you. Other than that I have no clue as to what could have caused a render crash for you. As shown below this was a Test I ran on my new PC as I was getting set up, the File name I entered was Simple_test the rest the program did....
Yeah, it didn't let me get that far. It had rendered frames 1-5 and crashed on frame 6. It was a .30 shading rate, the settings were good but not outrageous so that shouldn't have taxed my system. :(
