anyone come across a carrara fur preset for dog 8?
  • StezzaStezza Posts: 8,951
    have any Carrara users purchased Dog 8?  wink
    I haven't .. and haven't noticed any images of any either being posted. hmmmm...
    i'm very behind on my installs.
    tee hee i need to decide on my doggie style
  • Bunyip02Bunyip02 Posts: 9,299
    edited January 2020
    Dog 8 needs to be converted to Blended Weight - https://www.daz3d.com/forums/discussion/comment/3750916/#Comment_3750916
    Post edited by Bunyip02 on
    edited January 2020
    French Bulldog pic posted, done a few others as well ! https://www.daz3d.com/forums/discussion/comment/5244771/#Comment_5244771
    https://www.daz3d.com/forums/discussion/comment/4610606/#Comment_4610606
    with so many images it all gets lost in the mix laugh
    I remember them now you mention it, though didn't realise they were dog8 .. yes
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,697
    I have used the Benji fur on other woofers, I did a few crappy videos with Carrara fur too but nothing memorable
    edited January 2020
    I also use the Mil Dog & Pup as they have more breeds than Dog 8, was thinking about getting the Hivewire one as well.
    EDIT: Got the Lorez Dog, need to do a few more renders with that one ! https://www.daz3d.com/forums/discussion/comment/5031891/#Comment_5031891
    edited January 2020
    while the Dforce hair is PA only the strand based hair is available to all
    so
    my question is how much of this is accesible in the API
    could someone use the information to convert to Carrara hair parameters?
    the Carrara hair is actually readable in a text editor so in theory one would not even need to use the SDK
    rather populate a .car file with the right values
    still beyond my skillset
    the big drawback to LAMH was it was encrypted I could not read those files and had trouble getting the density maps out
    these are actually user facing files in DAZ studio Strand based hair
  • HeadwaxHeadwax Posts: 10,494
    hya I have made a few presets I'll upload them when I get a chance - my dropbox is full - - recently discovered you can use a texture map for the hair denity thickness and length distribution in the hair shader
    not perfect but you can blurr the distribution shader near the paws
    1200 x 1097 - 253K
    2000 x 1500 - 439K
    2000 x 1500 - 456K
    2000 x 1500 - 614K
    example
    the strand based hair as I said has actual density maps in the runtime texture folders
    Ah thtank goodness ! I sorry I missed that. save me opening a drop box account :) cheers
    edited January 2020
    Using the Dog 8 German Shepherd density map
    1600 x 1200 - 3M
    my furs are horrifying
  • SileneUKSileneUK Posts: 1,980
    Would love to see these when you have time to post them to Dropbox.... I have experimented a bit, but never seem to get the fore-leg and paw areas right... tails, and ears, too for that matter. So a sample of length and density maps would be amazing!
    heart  Silene
    very nice El Bunyip02 :)
    crazy mad person Wendy the best - couldnt see the desnity maps in the textures folder
    SileneUK - here's couple rough and not so rough - just a metter of blending the blacks and whites to your taste and dropping it into the density part of the shader
    I trimmed some of the area by hand in the hair room
    to use - drop the car file in your objects folder, then you can drag it onto the dog - you have to add that dogs texture file to the hair colour shader of course (roiot and tip)
    there's quick whiskers one as well
    https://www.dropbox.com/s/myakvtb5vyjhegd/Dog8HairSlightlyLonger.car?dl=0
    https://www.dropbox.com/s/o3oryz8inkiuwld/Dog8Whiskers.car?dl=0
    https://www.dropbox.com/s/m5mo4rl0wvxnfds/HairBenjiUpload.car?dl=0
    https://www.dropbox.com/s/11et1layhmdlmx1/HairDog8Variation1.car?dl=0
    https://www.dropbox.com/s/fpki8yy8m3w71qv/HairDog8Variation3.car?dl=0
    hopefully one will work okay? :)
    Thanks so much... I won't have my machine back for a few more days, but am downloading these and am keen to try them. Once I understand the principle better, I hope to make some of my own instead of using the density brush in the hair room which is hit or miss.
    yes  Silene
    edited January 2020
    It'
    s pretty simple when you get the hang of it
    Here's a lorzenso template exported from carrar
    you just paint on the template black and white - where white is you get hair denser, or longer  (so in these exam,ples you need to invert the map once you put it in the hair shader (density and lenghth)
    if you gausian blur the the maps it gives a neater finish
    In these examples I have added two lots of hair to Lorenzo - one for beard and one for hair
    the images are labelled
    hope this helps ? :)
    they are rough jobs
    you can see I have made a length one for the beard to make it longer in the middle
    1206 x 1314 - 392K
    815 x 1058 - 226K
    2000 x 2000 - 66K
    2000 x 2000 - 64K
    2000 x 2000 - 56K
    2000 x 2000 - 1M
    Post edited by Headwax on
    edited January 2020
    But are you doing that in a texture file vs using the density painting tool in the hair room (the two tools on top left of tool bar) for your dogs.as you did for the beards above?  I use that all the time, but it is hard to 'paint' on thin shins of animals, wolves or dogs as an example. On humans faces or large areas, it's not difficult, just on skinny objects.  In the past I have tried to make a standalone density map b/w file using the main texture file as a template, but I was not getting a good result.  I am fine doing height maps, so I have a general knowledge of how to use shades of gray for effects... but for your beards, did you just use the face texture map for that model and make the beard map using that as a template (eg doing a layer thingy in PS and then just saving the beard?)
    When I open your files when I get my machine back, will I see a texture file that you have dropped into the hair shader tree that shows how you got the extremity hairs sorted?  I did not see any separate files in your dropbox set, only .car files. Are they embedded some how?  I am sure it's me and it will be all obvious once I can open .car files again!
    heart  Silene
    Post edited by SileneUK on
    edited January 2020
    Hi Silene,
    I am painting in the hair room then using the distribution shader in the hair shader to fine tine it.
    As tyou know you can only select whole polys in the hair room so its is pretty inacurate on low poly models.
    The shader map (The black and white one helpd you finetune it.
    Yes, the trick is to blend it a little with gausian blur so the edges of your painted map arent crisp.
    Hi, yes you will see the texture files in the hair shader - in the density and length sections. I saved the car file with textures included - so it should work.
    Yes it will be nice when you get your macine back - very frustrating to have no access.
    Here is what I painted in the hair room - you can see on the right image clear hair filements that have no hairs on them - that's because of the distribution shader.
    They still get little nodes and drape when you 'drape' - so try not to get too many of them (For example, don't just select the whole body in the hair room - like I did at first - t)
    1514 x 1163 - 644K
    edited January 2020
    Here are the dog 8 distrubition maps - you can see they are pretty simple - one for density t'other for length
    I just painted in a new PSD layer over the texture map in this case - which I cant post of course.
    You can see for the paws I just used a simple gradient (drew a circle arround them and filled it with a black and white gradient
    Normally you would do it over an exported Uv Template to get it more accurate
    2000 x 2000 - 372K
    2000 x 2000 - 358K
    Thanks, Andy... I see it now. I'd never used distribution maps before, so this will be fun. I can see how useful they could be when using hair for grass areas, too!  Working with Car hair is one thing I really enjoy, so look forward to this.  You are right about not always painting hair on a whole area to be haired... it gets cumbersome. and  often does not matter where it does not 'show'.
    yes  Silene
    edited January 2020
    huh, we can use alpha masks with hair?
    like if i blended noise speckles in, it could sprout hairs from the noise speckls?
    Post edited by Mistara on
    yes it's pretty cool aye?
