fast way for selecting/editing viewport cam in scene or cam pane?
in The Commons
I want to quick check cam views while working with 20 or more cams and adjust its visibility (eye closed/open).
Is there an easy way to do current viewport cam un/visible (closed/open eye for it) and select it in scene pane or parameter pane?
I manually search in whole list of cams of the cam pane for corresponding viewport cam name.
Can I somewhere see the current viewport's cam's full name?
Generated cams have similar names only different at the end and fullname is not shown in right upper corner in viewport and also not on mouseover and not when opening the menu it is not highlighted.
My Selection Tools scripts include one for selecting the camera used to view the scene (and one to view the scene through the selected camera) https://www.dropbox.com/s/z6ceaiasl8ll5u6/RHSelectionTools.zip?dl=0
thank you very much
I already found your camera stepper in another thread :D
sounds like what I am searching for - perhaps when combining it. I will look at the code
