victoria 4.2 remove undergarment?
SoulUnitSoulUnit Posts: 112
Hello, super noob question, working with v 4.2 and cant seem to remove the undergarments other than to put nylons on her and that does not work for this shot see attached, I am sure I am missing something, any help appreciated.
  • Scott LivingstonScott Livingston Posts: 4,348
    The undergarments are actually painted onto Victoria 4.2's default skin texture. In order to remove them, you should use a different skin texture (pretty much any skin texture for Victoria 4 would do).
  • SoulUnitSoulUnit Posts: 112
    Thanks for the speedy reply!
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,420
    The genesis female Lana has the the same UV mapping as V4 so apply her skin, you can do this by copying pasting surfaces with genesis loaded as well then save it as a material preset for V4
    or use the poser format material pose file
  • Richard HaseltineRichard Haseltine Posts: 108,967
    There should be an AllNaturalNG preset in the Materials Sample Res folder which will replace the painted bikini with skin matching the rest of the body (but no nipples or genital detail).
    edited January 2014
    Great thank you all! I could not find "AllNaturalNG" on my hard drive not sure where I could get this?
    Post edited by SoulUnit on
    \People\Victoria 4\Materials\V4 Sample-Res\!All_Natural_NG.dsb for the DAZ Studio materials, or Pose library DAZ's Victoria 4>Mat>MATerials Sample-Res>!All_Natural_NG for the Poser mat file.
    OK found that one !All_Natural_NG.dsb I'll give it a try, thanks
