what is a splat? what it for?
if i try to convert to a vertex obj, it has no geometry
  • Steve KSteve K Posts: 3,535
    "A Splat primitive is a billboard plane that always faces the camera, and is most often used to display textures that have alpha channels. For example, you can use a Splat primitive, and apply a rendered tree for a texture, using an alpha channel to remove the solid background color. Repeat the Splat object several times and you can have a forest without the geometry overhead."  I don't use this much, but I do use billboard trees that I bought, gives a nice background and hides the horizon line.
    edited January 2020
    thanks.
    couldn't put a hdri image on it.  the milkyway hdr not gicing much light to the scene.
    the curve woulda been good for a deathstar attacksmiley
    oh gahhh, that horizon line.  i tried to lower it -10000.00 in but is still rendering.
    rendering some terrains bg
    Post edited by Mistara on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,582
    reminds me, better buy toilet duck ...
  • DiomedeDiomede Posts: 15,459
    Chohole said:
    That looks exactly like a naked Vicky in a temple with a sword.
    - or maybe it is a rorschach test.  blush
    think it might be a radical isotope  lol
    there no way to render a hdr image on a plain or a prop?
    can bryce do it?
    You set HDRI up in the lighting lab
    i want the image
  • StezzaStezza Posts: 9,243
    if you have Affinity photo then you can load a HDRI into it and then save out in another format like jpg wink
    thanks.
    is the colors in the hdr supposed to bleed into the render?
    mebbe its a dud.
    i vaguely remember AoA found a way to line up a scene with the 'the sun' in an hdr
    Yeah... I see the same thing!!!
    @chohle very cool splat!!!
    Mystarra said:
    thanks.
    mebbe its a dud.
    That was Dimention Theory. He lines up the sun of a IBL map. I believe he might even have some products that use that (?)
