Fit Control for G8F with add on Crashes
Hi,
Hoping someone can help with Fit Control G8F crashing problem. Love this product when it works!! I've been using G3F and her Fit Control (It works Fine) as a go between but not nearly as good as the real thing.
It happens immediately after the Pop up saying they're appied is closed by me. Numerous re-installs and this always happens after I install other products.
I've taken "My Library" out of the equation by pointing Daz at an empty "My Library". It still happens. Looks like a conflict between something from the Daz Store and Fit Control.
The clean "Log File" is attached. Hope you can Help!!
Thanks,
Paul
  • barbultbarbult Posts: 27,216
    I see rendering statements at the beginning and end of your log file. Are you running Fit Control while you are in Iray Preview mode? That seems like asking for trouble. Try it in Texture Shaded mode. Try it without the hair loaded in the scene. I suggest you post your questions in the vendor's commercial thread, where he is more likely to see it.
    If you have an empty library, how are you even loading G8F and clothing into the scene?
    Thanks ...... I'll try that.
    I keep all of my products that arent't from the Daz Store in the "My Library" folder.
    I Sent a message to Zevo about a week ago and haven't yet heard back.
    Hey Now !!!!
    Thanks much..... only one try ... but it worked. No Hair and No Iray.
    Paul
    yes Great! I'm glad you got it working.
    Once you've added the Fit Control morphs, you should be able to add the hair back in and use Iray preview again. I don't think dialing in the Fit Control morphs on the clothing will cause any problem.
  • Yep..... no problem. Thanks again.
