Anthropomorphs - Chimpanzee issues
I tried to use the the following product today, which I have used successfuly in the past with the same computer, and it is acting finicky.
https://www.daz3d.com/anthropomorphs--chimpanzee-for-genesis-8-male
I cannot merge the chimp into an existing scene without DAZ Studio crashing.
The only way I am able to use the chimp is to merge the figure into a new blank scene and render it that way. But if I try to save and reload the newly created scene with the chimp, I get the crash again (see log file below).
There is only one light in the scene and the Urban Skateboard product. That's it. This same exact scene will save and reload into DAZ with any other figure without any problems.
Does anyone know what the issue could be?? The log file does not say much.
Log File:
2020-01-01 11:14:19.363 Loading Startup Scene : C:\Users\Mikey\Desktop\von Hobo\Scenes\Chimp - Skate.duf
2020-01-01 11:14:19.434 Iray [VERBOSE] - IRAY:RENDER :: 1.13 IRAY rend stat : Lights memory consumption: 948 B (device 0)
2020-01-01 11:14:19.434 Iray [VERBOSE] - IRAY:RENDER :: 1.13 IRAY rend stat : Material measurement memory consumption: 0 B (GPU)
2020-01-01 11:14:19.434 Iray [VERBOSE] - IRAY:RENDER :: 1.13 IRAY rend stat : Materials memory consumption: 17.2461 KiB (GPU)
2020-01-01 11:14:19.487 Iray [INFO] - IRAY:RENDER :: 1.10 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 0.214s
2020-01-01 11:14:19.493 Iray [INFO] - IRAY:RENDER :: 1.12 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 7.84537 MiB for frame buffer
2020-01-01 11:14:19.551 Iray [INFO] - IRAY:RENDER :: 1.10 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.6875 GiB of work space (2048k active samples in 0.059s)
2020-01-01 11:14:19.552 Iray [INFO] - IRAY:RENDER :: 1.10 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
2020-01-01 11:14:19.590 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00001 iterations after 0.308s.
2020-01-01 11:14:19.593 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2020-01-01 11:14:19.609 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00002 iterations after 0.324s.
2020-01-01 11:14:19.635 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00004 iterations after 0.349s.
2020-01-01 11:14:19.649 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00006 iterations after 0.363s.
2020-01-01 11:14:19.668 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00008 iterations after 0.382s.
2020-01-01 11:14:19.685 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00010 iterations after 0.399s.
2020-01-01 11:14:19.693 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00012 iterations after 0.407s.
2020-01-01 11:14:19.718 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Device statistics:
2020-01-01 11:14:19.718 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (GeForce GTX 1070): 12 iterations, 0.348s init, 0.118s render
Are you saying that the merging causes an immediate crash, or that the merged scene can't be rendered without crashing? The log seems to suggest the latter. When was it last working, and was that with the same environment prop? Will the Skate Park render on its own?
It seems to be working fine now. Not sure what the problem was last night and earlier today.
I find that if I want to render something like the Chimps, that need a lot of memory, it's best not to do so after loading/clearing other scenes/renders, and just close then re-open Studio so it all starts fresh. Just clearing a scene does not fully clear the memory.
Thank you dragonfly
That's what I had to do here:
Very nice! I love it!
