iRay Render isn't starting rendering
Hello, I am trying to render a female character using multiple armors and she's sitting on the Dark Horse with the dark armor, and the file size is close to 21mb so it's not that big.... The problem is that in the rendering window the first image isn't loading even after 8 hours, the render box is showing something like '1.3 iRay rend stat: Native CPU code generated in 89.6s... What can I do? I even lowered the SubD of the horse from 3 to 2.
  • TheKDTheKD Posts: 2,711
    Hmmmm, are you trying to render at a massive size? Even for CPU render, you should be seeing something after 8 hours.
