Auto Fit Clothing default?
When you add a clothing item for Genesis 3 to Genesis 8 Figures, the Auto-Fit dialog asks for each item "what figure was this originally designed for?".
When a wardrobe item has a lot of parts, the dialog box has to be answered for each item, which can take time.
Is there any way to have this answered by default so I don't have to do it manually??
It seems to me if you are adding a G3 wardrobe, then DAZ Studio should know already that the item was designed for G3.
Just a thought and wishlist item. Would be so awesome!
    No it cannot be done automatically. What you can do is load each item, convert it, then save it as a conversion [separate folders, new names] so next time 'round you can load the already converted items.
    i am not a fan of the RSA converters since I find the results less than favorable, but the one for G3 to G8 works fairly well since G3 and G8 are nearly identical. the converter will save copies af all the G3 products you convert and then they load as G8 items.
    https://www.daz3d.com/clothing-converter-from-genesis-3-female-to-genesis-8-female
  • vonHobovonHobo Posts: 1,715
    thank you!
