Distortion in Genesis 8 Male
brynnamorgan
I had this issue about a month ago, so I reloaded Daz Studio and did my usual manual install of content. That's just me and how I work. I left off the extra morph packages for head and body, and installed the rest of the content. G8F came out just fine. Genesis 3 male and female also did. G8M is distorted, as if I turned on every morph to an extreme. Any suggestions?
Please put the Viewport in smooth sahded view if you are going to post an image of a nude figure, even if it doesn't have the anatomical elemnts attached.
That looks as if there is a shape with a non zero default. I seem to rcall that the Christian character did that on release, but an update fixed the issue - you can check the Currently Used group in the Parameters pane to see what is set to 1 (or at least is non-zero) on a newly-loaded figure.
Sorry about not using smooth shaded view.
There was one shape that didn't have a zero default. I bought him elsewhere and will check and see if there's an update. Once I zeroed that out, everything returned to normal.
Thanks for the assist!
