Problem moving content from C to D drives.
Haruki790
So I did a fresh install of 4.12 on my D drive,then copied my library onto the same while deleting the old ones on C drive.
DS loads fine,however the content in IM needs to be reinstalled for some reason,I'm sure my paths are correct but am
afraid if I reinstall it might go on C.
Below is what I'm seeing on CDM and IM,any advice would be appreciated.
Thanks
I think people have found issues using the root of drive - try putting you content in a sub-folder. Unlike the Content Management System, whichs tores only the relative path within the content directory, DIM has to install the exact location on disc (otherwise it could no reliably uninstall) so yes, you should ideally reinstall using the current directory - that is a right-click option in the Installed tab
Ok I'll reinstall using the new path in IM.
Thank You
