multiplane cyclorama question
WillowRavenWillowRaven Posts: 3,787
I bought the MPC a few years ago and still use it on occasion. When I use one of those freebie textures for it, I usually put it over an existing texture. Did a clear MCP come with the product? It would make things easier if I knew which one of my 'blanks' to use.
    You know, I don't remember if there was a 'blank' preset for it or not...and there used to be a nice tutorial on making new sets for it, I wonder if that is still around somewhere...
    I usually do much the same thing you do... Load the beach one, and then remove the picture and extras, save, and then load the freebie texture.
    I tend to just load the beach one and place the freebie texture over it.
  • RogerbeeRogerbee Posts: 4,460
    Same here,
    I never actually bought the Cyclorama, it came bundled with DS2 and I just saved all the folders.
    CHEERS!
  • WillowRavenWillowRaven Posts: 3,787
    OK ... So I guess I'm doing it the way I've been doing it.
    Thanks, guys :D
    Sorry it isn't easier. I actually like the cyclorama idea. Wish there were some more realistic ones sold in the store. But I guess because it is easy to get freebies they don't bother. =)
    Probably. I'm using one of Hobo's freebies for this particular book cover. He has so many ...
    edited January 2014
    In DS 4.x it won't be too difficult to set up a blank preset for it...or set up any of the freebies as presets.
    Rogerbee said:
    Same here,
    CHEERS!
    That and the trees and stuff from the Fairy Forest (or whatever it was called)...
    Post edited by mjc1016 on
  • PennamePenname Posts: 347
    I have something under Figures/Environment/DAZ Environment that's called "!!Blanked_Environment". But it might have come with the Playsets? Until I discovered that, however, I just put another texture on top of one of the existing ones, and it's always worked fine. If it ain't broke and all that.
