Weird problem with forehead/hairline when rendering
Hello!
Sorry to bother you all but im super new to DAZ 3D and everything seems to be working fine save for when I try to render Olympia here something weirds going on with her forehead. (this appears literally only in the resnder every time. the model itself doesent seem to be having any problems) I dont have the technical know how to describe it to search in google and im not sure what might be causing this problem...
any help would be greatly appreciated! Thank you!
Post edited by Chohole on
Make the haircap invisible...in the scene list...a workaround...
Is the figure more or less where it loaded, or have you moved it in the 3D space to a new location?
Find the fit adjustment morphs for the hair. If there is an expand all or expand forehead. or the like, adjust it till that goes away.
Go to size (usually crown size) in the hair and reduce to -8% also if you've moved the character from X0, Y0 that can also result in this error.
