3DS Max (.max) scenes in Daz
There seems to be a lot of products/resources online which come as .max 3d file format.
Is there a way to use these scene files in Daz?  And what about autodesk fbx versions?
what would that workflow look like?
  • well since for starters you need 3Dstudio Max to open a .max file I think once you look at their subscription only plans you will go from lilweep to bigwail cheeky
    from there it only gets worse ....
  • lilweeplilweep Posts: 2,746
    true, I am definitely not interested in learning 3DS Max nor paying for it, so i guess that's out of the question then.
    What about Autodesk FBX versions of Max scenes?  Do those import to Daz Studio?  I know daz can be weird with FBX.  I assume they can be opened in Blender?
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,130
    edited December 2019
    there is yet another recent thread on FBX, its not pretty
    https://www.daz3d.com/forums/discussion/372701/did-daz-studio-4-12-fix-fbx-import#latest
    obj is likely your only option and you probably have to chase up all the textures and load in surfaces as well
  • FSMCDesignsFSMCDesigns Posts: 12,844
    yeah, .MAX files will only open with 3DSMax and I have yet to get a fully functioning rigged FBX model to import into DS, lord knows I have tried so many. It's odd that they work great in carrara, but not DS.
  • kyoto kidkyoto kid Posts: 41,876
    ...there are still a lot of nice freebies in .3ds format
    true, but then you need to convert them to OBJ to use in DS.
