3DS Max (.max) scenes in Daz
There seems to be a lot of products/resources online which come as .max 3d file format.
Is there a way to use these scene files in Daz?  And what about autodesk fbx versions?
what would that workflow look like?
  • well since for starters you need 3Dstudio Max to open a .max file I think once you look at their subscription only plans you will go from lilweep to bigwail cheeky
    from there it only gets worse ....
  • lilweeplilweep Posts: 2,873
    true, I am definitely not interested in learning 3DS Max nor paying for it, so i guess that's out of the question then.
    What about Autodesk FBX versions of Max scenes?  Do those import to Daz Studio?  I know daz can be weird with FBX.  I assume they can be opened in Blender?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,514
    edited December 2019
    there is yet another recent thread on FBX, its not pretty
    https://www.daz3d.com/forums/discussion/372701/did-daz-studio-4-12-fix-fbx-import#latest
    obj is likely your only option and you probably have to chase up all the textures and load in surfaces as well
    yeah, .MAX files will only open with 3DSMax and I have yet to get a fully functioning rigged FBX model to import into DS, lord knows I have tried so many. It's odd that they work great in carrara, but not DS.
  • kyoto kidkyoto kid Posts: 42,409
    ...there are still a lot of nice freebies in .3ds format
    true, but then you need to convert them to OBJ to use in DS.
