Carrara Non Photo Realistic Works
18081838586100
  • Bunyip02Bunyip02 Posts: 9,302
    edited December 2019
    There be Dragons...
    Carrara Terrain, PBR shader
    Bryce terrain
    1600 x 1200 - 5M
    1600 x 1200 - 5M
    Post edited by Bunyip02 on
  • PhilWPhilW Posts: 5,162
    Great images - I'm a big fan of Tim's skies too.
    Thanks Phil - Tim's Carrara Skies & Lightdomes are a go to item for my renders !!
    Light check
    Abandoned Factory - inLite studios
    1600 x 1200 - 3M
    Another Near Naked Vicky In A Temple - Without A Sword
    Carrara terrain
    1600 x 1200 - 4M
    Beastie
    Basic Tube - P3D Space Junk
    1600 x 1200 - 5M
    Beastie 2
    Carrara terrain, PBR shader
    1600 x 1200 - 4M
    Dino
    1600 x 1200 - 5M
  • DiomedeDiomede Posts: 15,410
    Oh, wow, these are wonderful renders, Bunyip.  Special shout out to the headlight effect in the classic car image.  yesyes
    I agree - and the NPR look of the Vicky in the Temple is particularly note-worthy for me too.
    Post edited by PhilW on
  • Bunyip02 said:
    Beastie 2
    Love it!   Textures, colors, pose, everything.  How did you apply the PBR shader?
    Thanks !
    Thanks !
    Bunyip02 said:
    Beastie 2
    Thanks !
    Applying the PBR shader
    First of all you need Philemo's wonderful PBR lighting plugin - https://www.daz3d.com/forums/discussion/240836/new-beta-available-pbr-microfacets-disney-fresnel-and-tutti-quanti/p7
    1. Select the terrain (or item)
    2. You need a donor DUF file, drag and drop into the Effects tab PBR Studio import
    3. Double click on the Default PBR shader to open it.
    4. In the Multi-Channel Color slot change the texture map to the one you are after
    5. In the Multi-Channel Bump slot, change Texture Map to Normal Map then load the normal map.
    6. In the Metallic slot I have been inserting the Roughness maps
    7. In the Ambient Occlusion slot I insert the AO texture
    8. Drag the modified PBR shader onto your Terrain (or item)
    9. If your surface is so large it's causing distortion of the shader, load Triplanar in the Color slot, Bump Slot & other slots you have inserted texture maps.
    10. Click on the Transform tab
    11. Click the Enable Transform box. Change Overall Scale to suit.
    2777 x 1037 - 477K
    2777 x 1039 - 572K
    2771 x 1037 - 628K
    2780 x 1033 - 909K
    2773 x 1031 - 547K
    2777 x 1037 - 547K
  • Thanks for all of those nice details, Bunyip.  I still haven't downloaded Philemo's plugin yet.  I do recall the thread, and remember it was a little deep for me at the time.  Maybe after the holidays there will be time to play with it, and ask further questions.  Good to see it is working for you!
  • HeadwaxHeadwax Posts: 10,525
    Bunyip02 said:
    Another lady - shorter dress this time...
    Used a background image instead of a scene.
    wow that's a 'wow'!!!
    I see I've missed 124 posts!!
    Thanks, looking forward to seeing some goodies from you as well !!!
  • VyusurVyusur Posts: 2,235
    Trying different styles during coffee break.
    1300 x 1690 - 6M
    1300 x 1690 - 4M
    Post edited by Vyusur on
    Very nice Vyusur, colour one is my favourite ! Hope you have more coffee break inspirations !!!
    Knight
    1600 x 1200 - 4M
    Another Alien
    1600 x 1200 - 5M
    Veronika - these are stunning.  Wonderful styles.  Like Bunyip, I'm looking forward to more of your coffee breaks.
    Bunyip - Thanks for the detailed tips for the PBR shader.  Very helpful.  You've become a master of different approaches to non-photoreal renders.  Keep it up!
    Bunyip, Ted, thank you guys!
    Bunyip, my first pic is your favorite Dark-Side, those ugly PaintShopPro, that I recently bought. Your pictures are so seductive.
    Hello Vyusur, glad you added some more tools to those wonderful art skills you have !!!
    Another Dino
    Bryce/Carrara terrain
    1600 x 1200 - 5M
    Alien Portrait
    Background Picture - A_Sunbeam_strange-worlds_59714
    1600 x 1200 - 4M
    Beastie Portrait
    Background Picture - 85_GillBs_OldMasters
    1600 x 1200 - 5M
    Once again the Aliens take over....
    https://www.daz3d.com/solaris-corridor
    1200 x 1542 - 4M
    1600 x 1200 - 5M
