Installed content search
Hello everyone,
I'm new to DAZ Studio
I'have installed content from a .zip archive (from Renderosity) by merging the runtime folders..
Now I can load the content successfully
The problem is if i use the search function of the content library I don't get any results..
Also, are metadata files usually stored in data folders?
If my zip doesn't have any data folder the installed product will not appear in the smart content, am I right?
Any suggestion for keep a well organized library is well welcomed
Thanks
The data folder holds the native geometry, morph, and rigging information - the metadata files, if any, are in Runtime\Support. Non-DAZ content will rarely have metadata, but you can categorise the content yourself if you wish - or even create metadata to add it to Smart Content.
Thank you!
I realize I can't also create subcategories.. I get "unable to create container:" error
Reading other post is suggested that it can be caused by CMS that isn't correctly started.
I've tried to manually stop it (Stop DAZ Content Management Service) an restart it.
And finally to change VerboseLevel value in the "DAZ Content Management Service.ini" to 3 instead of 0
This is what I get in the log:
Wed Jan 1 2014 18:50:45.905187 DAZ Content Management Service (4.8.1, Kernel 4.8.1 )
Licence license_emb_4422548148518942 is registered to DAZ3D.
Valid until 9999-12-31. Subscription valid until 2013-02-08.
Maximum number of connections: 5
Wed Jan 1 2014 18:50:45.928987 (TID 140735298859792): Database engine inited
Wed Jan 1 2014 18:50:45.963023 (TID 140735298859792): VProject facilities are disabled since no appropriate license found
Wed Jan 1 2014 18:50:45.963061 (TID 140735298859792): Server started
Wed Jan 1 2014 18:50:45.963079 (TID 140735298859792): Non-secure port: 27997
I can't use the search function nor create sub-categories...
Looks like it's running properly from that log snippet...but that only looks like a few fractions of a second's worth of log data....is there more, like an entry if you try to create/categorize something?
This is what is contained in the last .log in the "vlogs" folder in /Library/DAZ 3D/Content Management Service
It doesn't change if I try to create sub-categories
Do your DS has connection to the CMS? if you set loglevel=3 you will see a lot of things in the log whenever you browse the content library.
Check you DS log if it says something about error connecting to ValentinaDatabase.
And, what version of OS are you running on? There are sometimes some issues starting the CMS on 10.9.
Thanks everyone for the help.
I'm on 10.9.1
Where can I find the DS log?
Menu: Help -> Troubleshooting -> Show Log file...
this is where vaentinadatabesa appear in the log:
WARNING: /src/dzvalentinaobjectdatabase.cpp(38): DB Register Open error: Cannot establish VC_Connection with remote server.
Make sure the server address and port number are correct.
That's what I suspected.
If you use Activity Monitor.app can you see the process DAZ Content Manager Service in the list (set to show all processes)? If not try to restart your system, does the CMS start then?
Well, it was not there.
After restarting it's there but it's the only process, except Time Machine, is grayed out.
I've tried again creating sub categories without luck.
http://www.tekrevue.com/tip/use-activity-monitor-energy-tab-os-x-mavericks/
"Apps that are no longer running but have recently used a measurable amount of energy will be displayed grayed out."
So it's not running at present, right?
Yupp, it stops for some reason, most likely a corrupt database file.
You can try to delete the file named ContentDB.ind (it's the index-file).
Did you see more in the log now btw?
Can't find any ContentDB.ind, where it's supposed to be? I've looked in /Library/DAZ 3D/Content Management Service
Now CMS totally disappear from Activity Monitor
I've tried restart DAZ and create a sub categories,
the last log lines now are:
+++++++++++++++ DAZ Studio 4.6.1.39 starting +++++++++++++++++
Platform bits: 64
Qt Version: 4.8.4
Running on Macintosh OS Unknown
Current DateTime:
Loc: gio gen 2 18:23:03 2014
UTC: gio gen 2 17:23:03 2014
Temp Data:
Location = /Users/ale/Library/Application Support/DAZ 3D/Studio4/temp
Disk Total: 370.8 GB (398248099840)
Disk Avail: 233.0 GB (250189807616)
Locale: it_IT
No translator found.
Error reading application data!
WARNING: /src/sdksource/basictypes/dzsettings.cpp(722): Index out of range in DzSettings::getKey()
Reading style definition /Applications/DAZ 3D/DAZStudio4 64-bit/resources/style/Highway.style
Creating managers
Reading help index
Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/DAZ Studio/DAZStudioHelp.dsx
Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/EXPExporter/ExPExporter.dsx
Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/FBXExporter/FBXExporter.dsx
Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/FigureSetup/FigureSetup.dsx
Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/JointEditor/JointEditor.dsx
Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/LayeredImageEditor/LayeredImageEditor.dsx
Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/MorphLoader/MorphLoader.dsx
Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/MorphLoaderPro/MorphLoaderPro.dsx
Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/PolygonGroupEditor/PolygonGroupEditor.dsx
Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/TextureAtlas/TextureAtlas.dsx
Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/WeightMapBrush/WeightMapBrush.dsx
Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/inlinehelp.dsx
Scanning import folders
Scanning content folders
Using GLEW 1.9.0
Supported OpenGL extensions:
GL_ARB_color_buffer_float
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_instanced
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_instanced_arrays
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_provoking_vertex
GL_ARB_seamless_cube_map
GL_ARB_shader_objects
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shadow
GL_ARB_sync
GL_ARB_texture_border_clamp
GL_ARB_texture_compression
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_non_power_of_two
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_transpose_matrix
GL_ARB_vertex_array_bgra
GL_ARB_vertex_blend
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_window_pos
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_clip_volume_hint
GL_EXT_debug_label : NOT INITIALIZED
GL_EXT_debug_marker
GL_EXT_draw_buffers2
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_specular_color
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture_array
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_s3tc
GL_EXT_texture_env_add
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod_bias
GL_EXT_texture_rectangle
GL_EXT_texture_shared_exponent
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_timer_query
GL_EXT_transform_feedback
GL_EXT_vertex_array_bgra
GL_APPLE_aux_depth_stencil
GL_APPLE_client_storage
GL_APPLE_element_array
GL_APPLE_fence
GL_APPLE_float_pixels
GL_APPLE_flush_buffer_range
GL_APPLE_flush_render : NOT INITIALIZED
GL_APPLE_object_purgeable
GL_APPLE_packed_pixels : NOT INITIALIZED
GL_APPLE_pixel_buffer
GL_APPLE_rgb_422
GL_APPLE_row_bytes
GL_APPLE_specular_vector
GL_APPLE_texture_range
GL_APPLE_transform_hint
GL_APPLE_vertex_array_object
GL_APPLE_vertex_array_range
GL_APPLE_vertex_point_size : NOT INITIALIZED
GL_APPLE_vertex_program_evaluators
GL_APPLE_ycbcr_422
GL_ATI_separate_stencil
GL_ATI_texture_env_combine3
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_IBM_rasterpos_clip
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_depth_clamp
GL_NV_fog_distance
GL_NV_light_max_exponent
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
OpenGL features for current hardware:
OpenGL provider: Intel Inc.
OpenGL renderer: Intel HD Graphics 4000 OpenGL Engine
OpenGL version: 2.1.0
Maximum number of lights: 8
Number of auxiliary buffers: 0
Number of texture units: 8
Depth buffer bit resolution: 24
Maximum OpenGL texture size: 16384 x 16384
Current OpenGL Texture Quality Setting: Good Performance
RGBA color bitplane resolutions: 8 8 8 8
Shadow mapping supported
VBO supported
*** Scene Cleared ***
Loading plug-ins:
libaniMate2.dylib
libdazscriptide.dylib
libdzalignace.dylib
libdzassetiofilters.dylib
libdzautofit.dylib
libdzautoriggerbasic.dylib
libdzautoshaderbakeractions.dylib
libdzbrycebridge.dylib
libdzbvh.dylib
libdzcolladax.dylib
libdzcomponents.dylib
libdzcontentdbeditor.dylib
libdzcontentlibrarypane.dylib
libdzcr2exporter.dylib
libdzcustomizedlg.dylib
libdzdelightrenderer.dylib
libdzdformeditor.dylib
libdzeasyloader.dylib
libdzexpexporter.dylib
libdzfbxexporter.dylib
libdzfbximporter.dylib
libdzfiguresetup.dylib
libdzhexagonbridge.dylib
libdzimageio.dylib
libdzjointeditor.dylib
libdzlayerededitor.dylib
libdzlayerfilter.dylib
libdzmacvideo.dylib
libdzmanualshaderbaker.dylib
libdzmaptransfer.dylib
libdzmorphfollower.dylib
libdzmorphloader.dylib
libdzmorphloaderpro.dylib
libdzobjexporter.dylib
libdzoptitexclothbasic.dylib
libdzpolygongroupeditortool.dylib
libdzprimitives.dylib
libdzpropertyhierarchyeditor.dylib
libdzpuppeteer.dylib
libdzpz3importer.dylib
libdzrenderedit.dylib
libdzrenderlibrary.dylib
libdzrslshadercompiler.dylib
libdzsavefilters.dylib
libdzscriptedrenderer.dylib
libdzscriptedsteps.dylib
libdzshaderbaker.dylib
libdzshaderbuilder.dylib
libdzshadereditor.dylib
libdzshadermixerbase.dylib
libdzshadermixergui.dylib
libdzsmartcontentpane.dylib
libdzspotrendertool.dylib
libdztextureatlas.dylib
libdztransferutility.dylib
libdzu3dexporter.dylib
libdzweightmapbrush.dylib
SDK_SceneInfoPane.dylib
libdzdrawstyles.dylib
libdzpowerpose.dylib
Error writing author data!
Total class factories: 1239
Creating interface
Successfully created OpenGL viewport for Viewport1.
Successfully created OpenGL viewport for Viewport2.
Successfully created OpenGL viewport for Viewport3.
Successfully created OpenGL viewport for Viewport4.
Executing startup script...
Started in: /Applications/DAZ 3D/DAZStudio4 64-bit
DAZ Studio Started
Creating Pixel Buffer
Pixel buffer - Width: 1024 Height: 1024
Compiling OpenGL Shader...
Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Shader Program successfully linked.
Which OS did you have when you installed the CMS?
I think there have been some enhancements to the installer (which you find in the DIM directory in /Applications/DAZ 3D.
If my memory is good I had this same OS.
Also I've tried to reinstall it delating the CMS folder
I don't have any DIM directory, I have
bin
displays
docs
Frameworks
imageformats
phonon_backend
plugins
resources
scripts
service
shaders
Uninstallers
The cms Installer is here
This is strange In /Applications/DAZ 3D I only have the "DAZStudio4 64-bit" folder
Have you downloaded the DAZ Install Manager at all?
I have installed DAZ from this file "DAZStudio_4.6.1.39_Mac64.app"
So I assume Install Manager isn't included in this file, right?
DIM: http://www.daz3d.com/get_install_manager/
sorry I've some problem downloading this.. the download suddenly stops and never ends..
will try to download again later
Finally, after a lot of tries, I've managed to download the DIM
I've installed it with no problem
Then I've stopped the CSM, delated the DAZ3D folder in Library, and installed from the file in /DAZ3DIM1/csm
During installation I get this error:
An unexpected error occurred while installing “DAZ Content Management Service.”
Please contact customer support for assistance (www.daz3d.com/i/support).
can this be because the file in your link is for 32bits? is there a 64 bit version?
Anyway after restarting my mac now the CSM is in the activity monitor.
Creation of sub categories still doesn't work
The error was a Gatekeeper problem.. Installed CMS again without any errors.
Creation of sub categories still doesn’t work
what the hell
I just rightclick on the item and do crate sub category.
Yes, then I input a name for the sub category and click ok.. than I get the error "unable to create container"
Weird, do you use any special characters like " ' in that name?
I did categorize before but got too much DB corruptions so I stopped.
I just made two (on 10.8 though), gonna try on 10.9.1, hang on.... works there too. Just created My 30s cat. I could create Bad ' Name " too so it must be you database.
To remove the database I really recommend stopping CMS, move the whole CMS folder to trash and empty trash to it's gone, reboot, then reinstall as it is run on startup it might be still running even if you stop it. Be sure it is gone before installing again.
If the database files have been corrupted, that is what you might experience (I've worked with Valentina in a project myself for over ten years and I know how picky it can be.) But databases are really just a way to corrupt things, they always become corrupted, part of their nature.
This is what I've done:
stopped CMS
controlled in Activity Monitor if it's effectively stopped
delated the CMS folder
restarted the mac
controlled in Activity Monitor that CMS isn't there
reinstalled CMS (this time I've got again the error, so maybe isn't Gatekeeper)
the files in CMS seems to be there so I've restarted the mac
controlled that in activity monitor CMS is running
opened DAZ and try creating sub folders with no luck
have you reimported MetaData after craetinga new DB to be sure that the tables are created in the DB. I'm stumped by your problem so thats why I try to think of different things that may fail.
You do that from DS.
I've tried installing Victoria 4.2 Base from DIM.
Then content DB maintenance -> reimport Meta-data..
nothing..
Also I don't see Victoria in smart content, is this normal?
Install Genesis starter essentials as V4 is old and might not have smart content (not sure if she do or not)
