Installed content search
musashi13musashi13 Posts: 44
Hello everyone,
I'm new to DAZ Studio
I'have installed content from a .zip archive (from Renderosity) by merging the runtime folders..
Now I can load the content successfully
The problem is if i use the search function of the content library I don't get any results..
Also, are metadata files usually stored in data folders?
If my zip doesn't have any data folder the installed product will not appear in the smart content, am I right?
Any suggestion for keep a well organized library is well welcomed
Thanks
«1
  • Richard HaseltineRichard Haseltine Posts: 111,647
    The data folder holds the native geometry, morph, and rigging information - the metadata files, if any, are in Runtime\Support. Non-DAZ content will rarely have metadata, but you can categorise the content yourself if you wish - or even create metadata to add it to Smart Content.
  • musashi13musashi13 Posts: 44
    Thank you!
    I realize I can't also create subcategories.. I get "unable to create container:" error
    Reading other post is suggested that it can be caused by CMS that isn't correctly started.
    I've tried to manually stop it (Stop DAZ Content Management Service) an restart it.
    And finally to change VerboseLevel value in the "DAZ Content Management Service.ini" to 3 instead of 0
    This is what I get in the log:
    Wed Jan 1 2014 18:50:45.905187 DAZ Content Management Service (4.8.1, Kernel 4.8.1 )
    Licence license_emb_4422548148518942 is registered to DAZ3D.
    Valid until 9999-12-31. Subscription valid until 2013-02-08.
    Maximum number of connections: 5
    Wed Jan 1 2014 18:50:45.928987 (TID 140735298859792): Database engine inited
    Wed Jan 1 2014 18:50:45.963023 (TID 140735298859792): VProject facilities are disabled since no appropriate license found
    Wed Jan 1 2014 18:50:45.963061 (TID 140735298859792): Server started
    Wed Jan 1 2014 18:50:45.963079 (TID 140735298859792): Non-secure port: 27997
    I can't use the search function nor create sub-categories...
    musashi13 said:
    Thank you!
    Looks like it's running properly from that log snippet...but that only looks like a few fractions of a second's worth of log data....is there more, like an entry if you try to create/categorize something?
    This is what is contained in the last .log in the "vlogs" folder in /Library/DAZ 3D/Content Management Service
    It doesn't change if I try to create sub-categories
  • TotteTotte Posts: 15,169
    Do your DS has connection to the CMS? if you set loglevel=3 you will see a lot of things in the log whenever you browse the content library.
    Check you DS log if it says something about error connecting to ValentinaDatabase.
    And, what version of OS are you running on? There are sometimes some issues starting the CMS on 10.9.
    Thanks everyone for the help.
    I'm on 10.9.1
    Where can I find the DS log?
    I'm on 10.9.1
    Menu: Help -> Troubleshooting -> Show Log file...
    this is where vaentinadatabesa appear in the log:
    WARNING: /src/dzvalentinaobjectdatabase.cpp(38): DB Register Open error: Cannot establish VC_Connection with remote server.
    Make sure the server address and port number are correct.
    That's what I suspected.
    If you use Activity Monitor.app can you see the process DAZ Content Manager Service in the list (set to show all processes)? If not try to restart your system, does the CMS start then?
    edited January 2014
    Well, it was not there.
    After restarting it's there but it's the only process, except Time Machine, is grayed out.
    I've tried again creating sub categories without luck.
    Post edited by musashi13 on
    http://www.tekrevue.com/tip/use-activity-monitor-energy-tab-os-x-mavericks/
    "Apps that are no longer running but have recently used a measurable amount of energy will be displayed grayed out."
    So it's not running at present, right?
    Yupp, it stops for some reason, most likely a corrupt database file.
    You can try to delete the file named ContentDB.ind (it's the index-file).
    Did you see more in the log now btw?
    Can't find any ContentDB.ind, where it's supposed to be? I've looked in /Library/DAZ 3D/Content Management Service
    Now CMS totally disappear from Activity Monitor
    I've tried restart DAZ and create a sub categories,
    the last log lines now are:
    +++++++++++++++ DAZ Studio 4.6.1.39 starting +++++++++++++++++
    Platform bits: 64
    Qt Version: 4.8.4
    Running on Macintosh OS Unknown
    Current DateTime:
    Loc: gio gen 2 18:23:03 2014
    UTC: gio gen 2 17:23:03 2014
    Temp Data:
    Location = /Users/ale/Library/Application Support/DAZ 3D/Studio4/temp
    Disk Total: 370.8 GB (398248099840)
    Disk Avail: 233.0 GB (250189807616)
    Locale: it_IT
    No translator found.
    Error reading application data!
    WARNING: /src/sdksource/basictypes/dzsettings.cpp(722): Index out of range in DzSettings::getKey()
    Reading style definition /Applications/DAZ 3D/DAZStudio4 64-bit/resources/style/Highway.style
    Creating managers
    Reading help index
    Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/DAZ Studio/DAZStudioHelp.dsx
    Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/EXPExporter/ExPExporter.dsx
    Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/FBXExporter/FBXExporter.dsx
    Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/FigureSetup/FigureSetup.dsx
    Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/JointEditor/JointEditor.dsx
    Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/LayeredImageEditor/LayeredImageEditor.dsx
    Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/MorphLoader/MorphLoader.dsx
    Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/MorphLoaderPro/MorphLoaderPro.dsx
    Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/PolygonGroupEditor/PolygonGroupEditor.dsx
    Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/TextureAtlas/TextureAtlas.dsx
    Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/WeightMapBrush/WeightMapBrush.dsx
    Reading help file /Applications/DAZ 3D/DAZStudio4 64-bit/docs/inlinehelp.dsx
    Scanning import folders
    Scanning content folders
    Using GLEW 1.9.0
    Supported OpenGL extensions:
    GL_ARB_color_buffer_float
    GL_ARB_depth_buffer_float
    GL_ARB_depth_clamp
    GL_ARB_depth_texture
    GL_ARB_draw_buffers
    GL_ARB_draw_elements_base_vertex
    GL_ARB_draw_instanced
    GL_ARB_fragment_program
    GL_ARB_fragment_program_shadow
    GL_ARB_fragment_shader
    GL_ARB_framebuffer_object
    GL_ARB_framebuffer_sRGB
    GL_ARB_half_float_pixel
    GL_ARB_half_float_vertex
    GL_ARB_instanced_arrays
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_occlusion_query
    GL_ARB_pixel_buffer_object
    GL_ARB_point_parameters
    GL_ARB_point_sprite
    GL_ARB_provoking_vertex
    GL_ARB_seamless_cube_map
    GL_ARB_shader_objects
    GL_ARB_shader_texture_lod
    GL_ARB_shading_language_100
    GL_ARB_shadow
    GL_ARB_sync
    GL_ARB_texture_border_clamp
    GL_ARB_texture_compression
    GL_ARB_texture_compression_rgtc
    GL_ARB_texture_cube_map
    GL_ARB_texture_env_add
    GL_ARB_texture_env_combine
    GL_ARB_texture_env_crossbar
    GL_ARB_texture_env_dot3
    GL_ARB_texture_float
    GL_ARB_texture_mirrored_repeat
    GL_ARB_texture_non_power_of_two
    GL_ARB_texture_rectangle
    GL_ARB_texture_rg
    GL_ARB_transpose_matrix
    GL_ARB_vertex_array_bgra
    GL_ARB_vertex_blend
    GL_ARB_vertex_buffer_object
    GL_ARB_vertex_program
    GL_ARB_vertex_shader
    GL_ARB_window_pos
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_blend_color
    GL_EXT_blend_equation_separate
    GL_EXT_blend_func_separate
    GL_EXT_blend_minmax
    GL_EXT_blend_subtract
    GL_EXT_clip_volume_hint
    GL_EXT_debug_label : NOT INITIALIZED
    GL_EXT_debug_marker
    GL_EXT_draw_buffers2
    GL_EXT_draw_range_elements
    GL_EXT_fog_coord
    GL_EXT_framebuffer_blit
    GL_EXT_framebuffer_multisample
    GL_EXT_framebuffer_object
    GL_EXT_framebuffer_sRGB
    GL_EXT_geometry_shader4
    GL_EXT_gpu_program_parameters
    GL_EXT_gpu_shader4
    GL_EXT_multi_draw_arrays
    GL_EXT_packed_depth_stencil
    GL_EXT_packed_float
    GL_EXT_provoking_vertex
    GL_EXT_rescale_normal
    GL_EXT_secondary_color
    GL_EXT_separate_specular_color
    GL_EXT_shadow_funcs
    GL_EXT_stencil_two_side
    GL_EXT_stencil_wrap
    GL_EXT_texture_array
    GL_EXT_texture_compression_dxt1
    GL_EXT_texture_compression_s3tc
    GL_EXT_texture_env_add
    GL_EXT_texture_filter_anisotropic
    GL_EXT_texture_integer
    GL_EXT_texture_lod_bias
    GL_EXT_texture_rectangle
    GL_EXT_texture_shared_exponent
    GL_EXT_texture_sRGB
    GL_EXT_texture_sRGB_decode
    GL_EXT_timer_query
    GL_EXT_transform_feedback
    GL_EXT_vertex_array_bgra
    GL_APPLE_aux_depth_stencil
    GL_APPLE_client_storage
    GL_APPLE_element_array
    GL_APPLE_fence
    GL_APPLE_float_pixels
    GL_APPLE_flush_buffer_range
    GL_APPLE_flush_render : NOT INITIALIZED
    GL_APPLE_object_purgeable
    GL_APPLE_packed_pixels : NOT INITIALIZED
    GL_APPLE_pixel_buffer
    GL_APPLE_rgb_422
    GL_APPLE_row_bytes
    GL_APPLE_specular_vector
    GL_APPLE_texture_range
    GL_APPLE_transform_hint
    GL_APPLE_vertex_array_object
    GL_APPLE_vertex_array_range
    GL_APPLE_vertex_point_size : NOT INITIALIZED
    GL_APPLE_vertex_program_evaluators
    GL_APPLE_ycbcr_422
    GL_ATI_separate_stencil
    GL_ATI_texture_env_combine3
    GL_ATI_texture_float
    GL_ATI_texture_mirror_once
    GL_IBM_rasterpos_clip
    GL_NV_blend_square
    GL_NV_conditional_render
    GL_NV_depth_clamp
    GL_NV_fog_distance
    GL_NV_light_max_exponent
    GL_NV_texgen_reflection
    GL_NV_texture_barrier
    GL_SGIS_generate_mipmap
    GL_SGIS_texture_edge_clamp
    GL_SGIS_texture_lod
    OpenGL features for current hardware:
    OpenGL provider: Intel Inc.
    OpenGL renderer: Intel HD Graphics 4000 OpenGL Engine
    OpenGL version: 2.1.0
    Maximum number of lights: 8
    Number of auxiliary buffers: 0
    Number of texture units: 8
    Depth buffer bit resolution: 24
    Maximum OpenGL texture size: 16384 x 16384
    Current OpenGL Texture Quality Setting: Good Performance
    RGBA color bitplane resolutions: 8 8 8 8
    Shadow mapping supported
    VBO supported
    *** Scene Cleared ***
    Loading plug-ins:
    libaniMate2.dylib
    libdazscriptide.dylib
    libdzalignace.dylib
    libdzassetiofilters.dylib
    libdzautofit.dylib
    libdzautoriggerbasic.dylib
    libdzautoshaderbakeractions.dylib
    libdzbrycebridge.dylib
    libdzbvh.dylib
    libdzcolladax.dylib
    libdzcomponents.dylib
    libdzcontentdbeditor.dylib
    libdzcontentlibrarypane.dylib
    libdzcr2exporter.dylib
    libdzcustomizedlg.dylib
    libdzdelightrenderer.dylib
    libdzdformeditor.dylib
    libdzeasyloader.dylib
    libdzexpexporter.dylib
    libdzfbxexporter.dylib
    libdzfbximporter.dylib
    libdzfiguresetup.dylib
    libdzhexagonbridge.dylib
    libdzimageio.dylib
    libdzjointeditor.dylib
    libdzlayerededitor.dylib
    libdzlayerfilter.dylib
    libdzmacvideo.dylib
    libdzmanualshaderbaker.dylib
    libdzmaptransfer.dylib
    libdzmorphfollower.dylib
    libdzmorphloader.dylib
    libdzmorphloaderpro.dylib
    libdzobjexporter.dylib
    libdzoptitexclothbasic.dylib
    libdzpolygongroupeditortool.dylib
    libdzprimitives.dylib
    libdzpropertyhierarchyeditor.dylib
    libdzpuppeteer.dylib
    libdzpz3importer.dylib
    libdzrenderedit.dylib
    libdzrenderlibrary.dylib
    libdzrslshadercompiler.dylib
    libdzsavefilters.dylib
    libdzscriptedrenderer.dylib
    libdzscriptedsteps.dylib
    libdzshaderbaker.dylib
    libdzshaderbuilder.dylib
    libdzshadereditor.dylib
    libdzshadermixerbase.dylib
    libdzshadermixergui.dylib
    libdzsmartcontentpane.dylib
    libdzspotrendertool.dylib
    libdztextureatlas.dylib
    libdztransferutility.dylib
    libdzu3dexporter.dylib
    libdzweightmapbrush.dylib
    SDK_SceneInfoPane.dylib
    libdzdrawstyles.dylib
    libdzpowerpose.dylib
    Error writing author data!
    Total class factories: 1239
    Creating interface
    Successfully created OpenGL viewport for Viewport1.
    Successfully created OpenGL viewport for Viewport2.
    Successfully created OpenGL viewport for Viewport3.
    Successfully created OpenGL viewport for Viewport4.
    Executing startup script...
    Started in: /Applications/DAZ 3D/DAZStudio4 64-bit
    DAZ Studio Started
    Creating Pixel Buffer
    Pixel buffer - Width: 1024 Height: 1024
    Compiling OpenGL Shader...
    Fragment Shader:
    Fragment Shader compiled successfully.
    Linking Shader:
    Shader Program successfully linked.
    Which OS did you have when you installed the CMS?
    I think there have been some enhancements to the installer (which you find in the DIM directory in /Applications/DAZ 3D.
    If my memory is good I had this same OS.
    Also I've tried to reinstall it delating the CMS folder
    I don't have any DIM directory, I have
    bin
    displays
    docs
    Frameworks
    imageformats
    phonon_backend
    plugins
    resources
    scripts
    service
    shaders
    Uninstallers
    The cms Installer is here
    450 x 193 - 29K
    This is strange In /Applications/DAZ 3D I only have the "DAZStudio4 64-bit" folder
    Have you downloaded the DAZ Install Manager at all?
    I have installed DAZ from this file "DAZStudio_4.6.1.39_Mac64.app"
    So I assume Install Manager isn't included in this file, right?
    sorry I've some problem downloading this.. the download suddenly stops and never ends..
    will try to download again later
    Finally, after a lot of tries, I've managed to download the DIM
    I've installed it with no problem
    Then I've stopped the CSM, delated the DAZ3D folder in Library, and installed from the file in /DAZ3DIM1/csm
    During installation I get this error:
    An unexpected error occurred while installing “DAZ Content Management Service.”
    Please contact customer support for assistance (www.daz3d.com/i/support).
    can this be because the file in your link is for 32bits? is there a 64 bit version?
    Anyway after restarting my mac now the CSM is in the activity monitor.
    Creation of sub categories still doesn't work
    The error was a Gatekeeper problem.. Installed CMS again without any errors.
    Creation of sub categories still doesn’t work
    what the hell
    what the hell
    I just rightclick on the item and do crate sub category.
    278 x 127 - 22K
    Yes, then I input a name for the sub category and click ok.. than I get the error "unable to create container"
    edited January 2014
    Weird, do you use any special characters like " ' in that name?
    I did categorize before but got too much DB corruptions so I stopped.
    I just made two (on 10.8 though), gonna try on 10.9.1, hang on.... works there too. Just created My 30s cat. I could create Bad ' Name " too so it must be you database.
    To remove the database I really recommend stopping CMS, move the whole CMS folder to trash and empty trash to it's gone, reboot, then reinstall as it is run on startup it might be still running even if you stop it. Be sure it is gone before installing again.
    If the database files have been corrupted, that is what you might experience (I've worked with Valentina in a project myself for over ten years and I know how picky it can be.) But databases are really just a way to corrupt things, they always become corrupted, part of their nature.
    Post edited by Totte on
    This is what I've done:
    stopped CMS
    controlled in Activity Monitor if it's effectively stopped
    delated the CMS folder
    restarted the mac
    controlled in Activity Monitor that CMS isn't there
    reinstalled CMS (this time I've got again the error, so maybe isn't Gatekeeper)
    the files in CMS seems to be there so I've restarted the mac
    controlled that in activity monitor CMS is running
    opened DAZ and try creating sub folders with no luck
    have you reimported MetaData after craetinga new DB to be sure that the tables are created in the DB. I'm stumped by your problem so thats why I try to think of different things that may fail.
    You do that from DS.
    I've tried installing Victoria 4.2 Base from DIM.
    Then content DB maintenance -> reimport Meta-data..
    nothing..
    Also I don't see Victoria in smart content, is this normal?
    Install Genesis starter essentials as V4 is old and might not have smart content (not sure if she do or not)
