mcjElasticSim - much awaited script for verlet based dynamics ( bounces )
mCasualmCasual Posts: 4,607
edited December 2019 in Freebies
i can't guarantee that's the final release
so in the coming days and week, keep an eye on it
https://sites.google.com/site/mcasualsdazscripts5/mcjelasticsim
2019 December 16th 03:53 PM - repaired the Load function
Post edited by mCasual on
«1
  • Gonna see if it work on my favorite youngster, since she doesn't have much to bounce. ;)
  • jag11jag11 Posts: 885
    Thanks, another great physics sim.
  • MythmakerMythmaker Posts: 606
    YAYYY!!!!
  • mCasualmCasual Posts: 4,607
    edited October 2016
    i added a short study about improving the Genesis3 animation
    https://drive.google.com/file/d/0B74NpQ_FHc6cMFZWdTdpcU41ODg/view?usp=sharing
  • RuphussRuphuss Posts: 2,631
    edited October 2016
    is this new i have to register google with your scripts ?
    i do not want to
    sorry did not see the down arrow
    everything nice as usual
    thanks for the script
    Post edited by Ruphuss on
    edited October 2016
    welcome
    when people go through the process i receive an email saying someone wants to be a sort of co-administrator of the site
    doesnt happen too too often though
    ( in other news i'll make an Arduino-to-DazStudio bridge and i'll complete the NewCastle prop ... yes the Newcastle prop )
    i do not want to
    800 x 600 - 144K
  • DigiDotzDigiDotz Posts: 515
    boing boing ..thanks !
    welcome
    ( coming up, an arduino-to-DazStudio bridge, then mcjNewCastle the final version  )
    tried the script with V4 and get some weird results
    x-translation to breastoutR works fine
    same to breastoutL gives only half the movement
    y-translation to breastup gives just 1 up-down
    workflow:
    targeting chestnode
    run sim
    runover sim
    modify
    exit
    targeting root node(not hip)
    and sim
    in.node sim
    out.note V4
    in,prop x-trans
    out.prop breastoutR
    sim to morph
    this works ok but as stated above
    various results with various morphs
    ok false alarm
    results are ok if you try out a bit
    i do not understand everything so far
    especially the translation from the sim node to the various morphs
    how much they are effected
    You got further than me Ruphuss
    Somethings gone awry here, on phase 1,  chest selected but the simulator appears by Aiko4's feet
    no hi def bounce action .. i mean verlet based dynamic simulations for me tonight
    the modify button will change this
    Got it.  look out!!  post the results soon  --in the best possible taste of course
     note that you can also re-position the simulator's base node "manually"
    do it when the timeline is at frame 0, to avoid having the base node move during the simulation
    if you select the simulator 'sim' node, you can also set it's initial position ( at frame 0 )
    if you go in the daz studio parameters tab for the 'sim' node, you will find all the simulation parameters in a sub-section named mcjSomething
    you could tweak the parameters there too
    when you intend to  target a specific morph or joint rotation, it's better to test them manually
    so you can see the limits and the ranges
    some breast morphs have a usable range of -100% to 100% ( -1 to 1 in mcjElasticSim parlance )  others need -800% to 800% !
    in the case of Genesis 3 i think, i had some confusing  results when "driving" the 'pectoral' joints, but it's worth the try
    personally for limb animations i use rotations and avoid tranlations
    edited October 2016
    I can only get some morphs to work if i first create a pose control
    ..also tested using a deformer and putting it as child of the simulator as an alternative. Just testing on a big belly.
    edit -scrub that belly heres the jelly (ish)
    Post edited by DigiDotz on
    edited February 2017
    UPDATE - UPDATE - UPDATE - UPDATE - UPDATE
    the script now displays the list of properties
    as pairs of Name / Label
    because, when a morph is injected into a figure, the channel name remains something cryptic like PBMCC_1
    in the first version of the script we only displayed the property name
    the new version displays them as pairs of Name / Label
    800 x 502 - 177K
    2017 April 8th 2017 - corrected a bug at line 1501  inCtl = obj.findModifier( inName ); needed to be inCtl = obj.findModifier( inPropName );
    this probably affected only non-morph properties and may explain why i didnt catch that bug
    so it means it's probably not true that nobody ever tried to use that script :D
    i will do a props-only test animation and post it after supper
    i had a more complex test animation in mind but this shows i was able to convert the red ball X Translation ( -10 cm to 10 cm ) into a stick (cylinder ) Z Rotation ( 10° to -10° )
    http://orig02.deviantart.net/345c/f/2017/099/1/5/mcjelasticsim_script_for_daz_studio_update_by_mcasual-db59qhd.gif
    edited April 2017
    second update
    this update fixes the issue wherein the list of property list was duplicated each time you change the node selection in the tranlators Tab
    note: i used mcjParent to make the small ball follow the simulator node
    because when it's parented to the simulator node its local transforms dont change
    and the translator system in mcjElasticSim is based on local transforms and morphs
    someday i may (should) add world-space transforms as source/destination "properties"
  • CGI3DMCGI3DM Posts: 281
    Great Tool, but no work in DAZ 3.1
    Bug  in lines 380,381,382, variable is duplicate with wTransFrmBtnAdd (372,373,374)  should be wTransFrmBtnAdd ---> wTransFrmBtnMod
    Lines BAD (380,381,382)
    var wTransFrmBtnAdd = new DzPushButton( transFormButtonsGB );
    wTransFrmBtnAdd.text = "Modify";
    connect( wTransFrmBtnAdd, "clicked()", transFrmMod );
    Change to :
    var wTransFrmBtnMod= new DzPushButton( transFormButtonsGB );
    wTransFrmBtnMod.text = "Modify";
    connect( wTransFrmBtnMod, "clicked()", transFrmMod );
    Work Fine DAZ 3.1.
    One suggestion, this tool would be very useful if it also had the option of "delay"(mcjlageffect), in the tab of translators.
    Find another bug, in the mcjCycleFilter.dsa script, which does not delete the keyframes with right click of the mouse.
    To correct this change the line 806
    If (prop.getKeyTime (i) == t)
    To
    If (prop.getKeyTime (i) .valueOf () == t .valueOf ())
    Thanks for your valuable scripts.
    regards
    edited May 2017
    UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE
    thanks to Armando_CG25 for pointing the bug and suggesting the delay effect
    There's now a Delay option and a Loop/Shift option
    you can use it to make one property animation follow ( or precede ) another property's animation
    600 x 600 - 36K
    800 x 600 - 24K
    edited May 2017
    thanks!
    see the update above or below
    edited May 2017
    Thank you very much, The delay works perfectly, but I think it still has other bugs.
    "Button Remove in Simulators" it does not work
    Lines 232
    connect( wSimFrmBtnRem, "clicked()", simFormBtnsGB );
    To
    connect( wSimFrmBtnRem, "clicked()", simFrmRem );
    "Button Add in Simulators" it does not work
    Lines 234,235,236
    var wSimFrmBtnAdd = new DzPushButton( simFormBtnsGB );
    wSimFrmBtnAdd.text = "Modify";
    connect( wSimFrmBtnAdd, "clicked()", simFrmMod );
    To
    var wSimFrmBtnMod = new DzPushButton( simFormBtnsGB );
    wSimFrmBtnMod.text = "Modify";
    connect( wSimFrmBtnMod, "clicked()", simFrmMod );
    "Button Defaults" it does not work?
    Post edited by CGI3DM on
    thanks ! updated
    UPDATE UPDATE V7 UPDATE UPDATE V7
    corrected 2 buttons in the interface
    thanks to Armando_CG25 for locating them bugs
    Thank you Mcasual, it works correctly
  • spearcarrierspearcarrier Posts: 711
    I haven't praised you lately, so. Praise. Praise.
    Now to download this and see if I can understand half of what was talked about. =^-^+
  • KoolapzKoolapz Posts: 3
    Just for information, this plugin still work well on Daz 4.12 pro (and that's pretty cool !)
    I just have a little bug when I use the button "load from" in simulator, all the informations in the txt file are pasted on the first input (the simulator name) and not input by input.
    Post edited by Koolapz on
  • 1gecko1gecko Posts: 309
    Fantastic!
    Will wait to work with it I think though... my frustration level/patience is extremely *low* between the holidays and several other issues!
    Does be the question: will you be porting this to Gen 8?  (not specifying 'Gen 8F' since... well, MOOBS - and therefore would definitely apply to George!)
    Oh, and - I hesitate to mention since it seems like "Well, now that you have given us the moon, how about the stars too" sort of question, but how difficult/impossible would it be to appy this to *hair*?  (so our more people not longer have 'helmet head')?  ... course, if you can do that - you *really* should sell it ;) just saying'.
