Ether Camera script - Render a cycling animation - from the POV of a non-cycling camera
mCasualmCasual Posts: 4,607
edited January 2014 in Freebies
ready ( i hope )
https://sites.google.com/site/mcasualsdazscripts3/mcjethercam
History
December 31st 2013 released
January 2nd 2014 - Added progress bar which allows interrupy Hardware renders and a button to interrupt FFMpeg
Lets say you created a 30-frames walk or dance cycle
if you want to render 20 of those cycles,
you could use a script like bLooper to copy the figure's keyframes ( 600 keyframes times 30 bones ... heavy stuff )
or use pose preset files and import them 19 times
or render 1 cycle and loop in in a video editor -
but your camera must stay put or hurry back to its initial position when the cycle ends
Ether-Cam will render your 30 frames cycle from the point of view of any camera. This camera can have a 300 frames travel path !
so you can watch that cycle that took you an inordinate amount of time to create from all the angles
very fast compared to the old ways
proof-in-the-pudding-demo-video
http://www.youtube.com/watch?v=XoRQ34QTvhg
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited December 2013
    with the help of the freeware utility ffmpeg
    this script will also help you convert series of numbered images into videos ( including ... basically all video formats and codecs )
    i'll probably include frame rate and render rate controls
    606 x 563 - 63K
    1280 x 720 - 108K
    almost ready
    got to write the darn manual,
    so users can be told 'read the darn manual'
    by rude people who use expressions like 'read the darn manual'
    606 x 626 - 63K
    Ready !
    i only tested on DS3 but i'll conduct tests on D|S 1, 2, 4
    i bet it will work as-is
    but just in case you may want to keep an eye on this thread for updates
    edited January 2014
    preparing to test it in DS4
    kinda get carried away on the test scene, but it will look better on youtube with a little effort
    see ... the eyes
    1600 x 900 - 1M
    1920 x 1080 - 881K
    1920 x 1080 - 2M
    edited January 2014
    turns out there will be an update - because for now the hardware renders seem uninterruptable
    to i'll borrow the method i used with texanim
    found this while testing in DS4
    1920 x 1080 - 2M
    the update will really be needed
    i found out that FFMpeg assumes that image sequences are 25FPS
    so in my test, my 1800 rendered frames came out as a 2180 frames 30fps Video !
    stay tuned - update soon, once i finish posting the big test video on youtube
    and for your patience , you get to see (another) sneak-peak preview image !
    1920 x 1080 - 1M
    -- Update -- Update -- Update -- Update -- Update -- Update -- Update --
    History
    and there will be a movie ! Yay!
    woohoo first new Youtube video of 2014
    it shows what mcjEtherCam was meant to do
    http://www.youtube.com/watch?v=I53QDybBmJ4
    1920 x 1080 - 1M
