Normal Map to Bump Map & Cut-Out Opacity Map
Does anyone have an easy way to convert this normal map image to a corresponding bump map(black & white) and a cut-out opacity map? I want to try using it for a cutout opacity map & bump map for wet skin. Looks like it might work well despite its small size.
    edited December 2019
    You could try using Materialize. It's free.
    Post edited by Catherine3678ab on
  • AJ2112AJ2112 Posts: 1,417
    +1
  • McGyverMcGyver Posts: 7,085
    Materialize is great, but if you don't get the results you like, you might want to try AwesomeBump...
    https://github.com/kmkolasinski/AwesomeBump
    it's free, it's got a few more options than Materialize (I think), but the GUI isn't as nice and there is a bit more controls to play with that might just complicate or confuse matters... But sometimes a pair of pliers and a visegrip may look similar and function similarly, but one might do a certain job better, so it's good to have both... it's always worth trying, especially if a tool is free.
  • RuphussRuphuss Posts: 2,631
    is it still a thing that you are not allowed to change mapnames in the cloudfile you use ?
    never heard of the mentioned little programs
    thank you for that
  • Thanks for the hints!
