Toon! Pro for Carrara
nDelphi
I am thinking about purchasing Toon! Pro for Carrara.
My reasons are many at this point. The number one, I want to move a Toon project from DAZ Studio to Carrara simply because Carrara does a much better job of handling importing of Object models.
I need to know if Toon! Pro has any limitations. Specifically, can I use it on volumetric clouds and on third-party products like the Brianorca's Ocean plugin.
I just will not go for it if it turns out to have such limitations.
You can not use on volumetrics and have a line effect. The plug in detects the edges of geometry and draws a line, there is no edge on a volumetric. I have used the toon shader on waters and that works fine. Only if there is geometry you can get the line to work. It also is not working on the hair.
So what about creating a primitive, or so, replicating it to look like clouds for the toon look, would that work, is that possible?
Are there any other gotchas I should know about?
Also, what about your starry skies, Dartanbeck, is that out of the question as well for Toon! Pro. If that doesn't work either, then perhaps I should start looking for toon backgrounds.
I will be working on sci-fi where Aircraft Carriers fly thru the skies and, of course, space, plenty of outer space scenes. :)
I just thought of something... the skies could be toonified in postwork. I could render the scene without the sky and then render the sky by itself.
That should work, the issue then would be trying to make them match later in style.
If it helps, I rendered this to an image sequence with Carrara's standard renderer and no toon effects. I then used Image Ready to batch apply Photoshop's Poster filter to the image sequence, then compiled the image sequence in Quicktime.
http://www.youtube.com/watch?v=WqkRvyKYDgo
Yeah, I think I will have to fall back on Filters in Photoshop or a toonifying app I have around here somewhere to do some of this stuff.
Things can never be simple.
For clouds, there is a nice Carrara Cumulus cloud object on ShareCG. I can see if I can find the link.
Found the link! Since it is an object, you should be able to toonify it.
http://www.sharecg.com/v/41244/browse/5/3D-Model/Cumulonimbus-cloud
Edited 'cause I forgot the friggin' link! ;-)
Thanks! I am checking it out right now.
