All renders are pixelated
For two weeks now, I have been trying to create renders, and every time I hit render, I either get an error message or my renders come out pixelated. Is anyone else having this issue and what can I do to fix thix problem?
  • What do you mean by pixellated? Noisy, or low resolution?
  • Very low resolution.
  • TheKDTheKD Posts: 2,711
    edited December 2019
    Go to render settings, in general make sure the drop down for render target is new window. Then go up to pixel size, and type in a larger resolution. Or you can use a dimension preset, and choose a larger preset.
    Post edited by TheKD on
  • I've tried that before I made this post, and the same results.
  • Please post a screen shot of the Render Settings pane Editor tab, showing the General property group.
  • I don't know what happened, but they seem to be rendering out fine. I guess the problem is fixed, and I did nothing different.
  • So just a little update, it was doing it again, and some how the "Progressive Rednering" was turned ON, and I have never had it on.  So problem is fixed!!!
    Where do you find "Progressive Rednering"
