How to do the opposite of dForce draping, ie elastic?
Is it possible to make a pair of suspenders act like elastic so they look right rather than "autofit" cling to a torso?
Or is there a pair of suspenders that are posable in a DAZ product? I want them off the shoulders & hanging from the waistband of the pants.
  • HaruchaiHaruchai Posts: 2,040
    With the right settings dForce will actualy do that. I have a set of lingerie where the woman's garters that do exactly that.
    It a freebie by DigiDotz http://www.digi-dotz.com/clothes/DDSweet.zip. It might be worth looking into the settings and seeing if you can apply them to a set of conforming suspenders.
  • nonesuch00nonesuch00 Posts: 18,848
    I gave up. Those suspenders aren't going to do nothing but explode no matter what I do.
  • felisfelis Posts: 6,198
    Depending on how those suspenders look.
    You could probably add a weightmap where you exclude both ends of the suspenders, as my guess would be that those are most likely to cause trouble. And it also make sense in order to keep them attached to whatever they are attached to.
    No, that was the 1st thing I did and turned off self-collide too. I will try again when I get my new desktop built with Ryzen 5 3600 CPU, that will make testing my guessing much faster, well 50% faster at least. I wish I could tell DAZ Studio to do dForce on the AMD Radeon RX 570 8GB since dForce uses openCL like the GPU driver does.
    Thanks. I downloaded and also accidently have done it on boxing shorts waist band too. I will look at both of them.
