G8f face - which morph should I be looking for the marked spot?
Well, like the topic says - can you tell me please how the spot on the arrow point is called and/or actually which group of face morphs can change it? I want to make the spot (don't know how it should be called) not so deep.
  • barbultbarbult Posts: 27,631
    That is the philtrum.
    Thanks again. You are my benefactor today:-)
  • SixDsSixDs Posts: 2,384
    One thing to be aware of, handel, (which you will undoubtably discover on your own), is that the philtrum sliders can influence adjacent facial elements and vice-versa. For example, adjustments to the philtrum can affect the configuration of the upper lip and the septum (that part of the nose that separates the nostrils and is connected to the philtrum at the top). Likewise, adjusting the mouth, upper lip (particularly the peaks) and septum can affect the philtrum. So care must be taken when adjusting these areas in order to be cognizant of their affect on adjacent features. A tiny bit here and a tiny bit there is the best way to go in my experience to arrive at what you are trying to achieve.
