WildDesigns Saucee 2 Overalls
kyoto kidkyoto kid Posts: 42,353
edited December 2013 in The Commons
...finally, after five years of waiting and hoping, a set of overalls for the girls that overlays with a top. Thank you thank you thank you.
http://www.daz3d.com/new-releases/saucee-2-overalls
Leela's so happy now.
Post edited by kyoto kid on
  • JessaiiJessaii Posts: 845
    They are adorable indeed :D
  • DireBunnyDireBunny Posts: 556
    They are pretty awesome, i am surprised there wasn't an official thread about them.
  • BurstAngelBurstAngel Posts: 768
    Is there a morph that flare the bottom pant legs for that 70's groove?
  • WildDesignsWildDesigns Posts: 302
    Thank you! I thought it would be a cute outfit for Josie and all the Gen 2 Females. I hope you get much pleasure out of using this set.
    "Is there a morph that flare the bottom pant legs for that 70’s groove?"
    Not really a bell-bottom look, but there is an Expand Hem morph.
    Happy Holidays!
  • Miss BMiss B Posts: 3,071
    I haven't gotten into Genesis 2 figures, but I have to say, this is an adorable set. Well done!!
  • SimonJMSimonJM Posts: 6,100
    A quick use of them!
  • kyoto kidkyoto kid Posts: 42,353
    ....nice.
    ...is anyone having issues with an odd bulge in the centre of the chest on the long sleeve top?
    ...until I can solve the issue with the long sleeve T-Shirt I mentioned above, combined the overalls with the T-Shirt from the Casual Jeans and T-Shirt for Genesis/G2F.
    Layers like a charm.
    Leela's very happy.
    1000 x 1000 - 741K
    Leela's very happy.
    Very cute! :)
    Might be your pose, but I'd like to see a picture, please. And the pose you used.
    Also, are you using DAZ Studio or Poser? If DAZ Studio, make sure the top has Smoothing on. By default it loads with it off. If Poser, it is probably related to the right and left pectoral. You can use Adjust Chest, or go into either the Gen 2 or the top and manually adjust the right and left pectoral. Please let me know.
    ...it also occurs in the default "T" pose.as can be seen here (used the Casual Jeans for TOS compliance).
    Using Daz 4.6.1.39. Smoothing is turned on. I have to crank the iterations up to something like 28 which still doesn't eliminate it totally (which can start introducing deformities in other areas at higher values). To eliminate the resulting pokethrough, I have to also adjust the "Bib Out" slider farther than it it needs to be which makes the overalls fit a bit odd.as the straps don't conform to the upper chest and collar area well.
    I remember there was some other clothign that had a similar issue a while back but don't know how that was dealt with (cold never get DFormers to work quite right since I started with Daz Studio years ago).
    800 x 800 - 143K
    That looks like a non-standard morph. It does not look that way on any of the standard morphs, so wondering what you are doing/using differently.
    Looks like it's 'over compensating' for your morph...try looking at the Parameters with 'Show Hidden' and see if there are any morphs dealing with chest/breast showing that don't look like they actually belong to the shirt. If it 'auto follows' it can pick up things that will, when added together do things similar to what is shown.
    Post edited by mjc1016 on
    ...checked the hidden morphs on the character for Chest and all there are are CTLRIG sliders which all show "Empty Range". Same for the Abdomen1 area.
    For the Top the only hidden parameters are for the Cuff morph sliders.
    I went through all the upper body and chest morphs for the top and none of them seem to eliminate the bulge when I change the settings so I'm really stymied. The bulge also appears in the bib portion of overalls, but is not quite as pronounced..
    I cranked up the smoothing iterations even more (110) and viewing in Wire/Shaded mode there is still a noticeable bulge in the centre of the chest on the top.
    The character is small breasted as she was created with the Growing Up morphs for G2F, however I still cannot see that as being the cause, for that bulge would still be there even in a more "well endowed" character, just not as noticeable.
    I'd like to find a way to solve this as I've been waiting nearly five years for a pair of overalls for this character (even tried modelling a set but with little success as my skills in that area are not that good).
    The upper body Morphs I used are:
    Areolae Diameter: -0.25
    Breasts Cleavage: +0.15
    Breasts Implant : -0.1
    Breasts Natural: . +0.12
    Breasts Upward Slope: +0.35
    Chest Depth: +0.2
    Collarbone Detail: +0.4
    Ribcage Size: +0.15
    Scapula Depth: +0.15 (shouldn't figure in)
    Below from Growing Up Morphs (Base Age Preset: Younger Teen)
    Chest Adjustment: - 1.8%
    Young Breast 1: 35%
    Young Breast 2 50%
    FBMs
    Adult Proportions: 45%
    Youth Morph: 38%
    Youth Posture: 50% (shouldn't figure in)
    ...a thought just occurred to me. Could this possibly be due to a preset in the mesh to prevent the top from conforming too tightly around the breasts (preventing the "saran wrap" look I see in some clothing) and is just showing up because the character I have is so petite?
    Just tested on the default G2F figure and there it looks fine, so that must be it as once I apply the Growing Up "Younger Teen" Preset, the "bulge" in the centre chest mesh of the top shows up noticeably again.
    So wondering if there is or could be a workaround or fix so this can be used on younger and more petite characters without the distortion because it is such a cute ensemble.
  • RenpatsuRenpatsu Posts: 828
    One thing that seems to help with extreme young shapes is to set "Adjust Chest" to -1 within the "Adjustments" on the top and then adjust smoothing/collision on the top to get it out of the body again. Not a perfect solution, but it seems to work somewhat.
    Edit: Smoothing I had on 5 and Collision on 10 for this quick test, but it is quite possible that lower values may work even.
    400 x 565 - 61K
    Post edited by Renpatsu on
    I did not do special morphs for the growing up morphs. I don't own them. But, that is the problem. Those are morphs and unless I fitted the top and overalls specifically for them, you will run into that problem. The morphs listed on the product page are the ones that work perfectly, and some others do work with the auto-follow feature. This set was for the older female figure and tested on such. I'm sorry.
    ...That's OK, I kind of got it to look right messing with DFormers, but seeing Renpatsu's work around I'll have to try that. Like I said it's a lovely set and I've been waiting for something like this for years.
    I have the Cute Farm Girl which I bought a couple years ago but the shirt is just a switchable transmap and not it's own individual mesh (same for Down on the Farm which is the Genesis version).
    I like the fact I the overalls and top are separate meshes as it allow for more mix and match possibilities.
    Maybe I can find someone who is good at scripting morphs (I don't know how to do it) to make a chest morph for more petite/flat chested characters.
    I sent you a pm message. :)
