Fitting Reby Sky hair to Genesis 3
Trex
I'm trying to get Reby Sky hair (for Victoria 4) to fit correctly to Genesis 3 female.
For some reason though, the forehead is really big when i fit to the new TG3 character.
You can see what I mean on the image below. I've added a G2F character to the middle as well so you can see the difference. The forehead gets bigger the newer the base model is.
Can anyone suggest a way I could get it to fit properly (or at least have a smaller forehead/lower hairline)?
Playing with the scale size of the hair doesn't seem to help. I've also tried using the transfer utliity with no luck, unless anyone can suggest some really specific setting I haven't tried yet.
Post edited by Trex on
Reby Sky hair is a tricky one to convert, because it has some extra bones in it that are needed if the (very impressive range of) morphs are to work. I've successfully fitted it to G2F in the past, by following the instructions in this tutorial, but the extra bone in G3F's neck seems to really confuse things.
You may just have to parent the hair to her head.
So sorry I forgot to reply to this earlier.
Your reply helped a lot. Thank you.
I have genesis 3 female for genesis 2, so my solution was to dial it in to G2F at 100%, then follow Sickleyield's tutorial. It fitted well to G2F, so I just parented it to my G3F character and it works.
