Victoria 6 - problem loading files
Huckleberry41Huckleberry41 Posts: 0
Hi everyone,
I keep having a problem with 2 files ("Victoria 6.dsf" and "CTRLVictoria6.dsf") when loading Victoria 6. Unfortunately I can't find a discussion about this problem on the forum. Maybe someone knows a solution to this problem or has an advice. Thank you for your help!
When I load Victoria 6 I get the following error message:
The following files could not be found:
/data/DAZ 3D/Genesis 2/Female/UV Sets/DAZ 3D/Base/Victoria 6.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Victoria 6/CTRLVictoria6.dsf
I used DIM to install DazStudio 4.6 and all the other contents. These are some of the contents I have downloaded and installed (along with some more content):
• DAZ Studio 4.6 (Mac 64-bit)
• Default Lights and Shaders for DAZ Studio
• Genesis 2 Female Starter Essentials
• Genesis 2 Female Starter Essentials PoserCF
• Subsurface Shader Base
• Victoria 6 HD
• Victoria 6 HD PoserCF
I use DAZ Studio 4.6 (Mac 64-bit) on a 2 x 2.26 GHz Quad-Core Intel Xeon , running Mac OS X 10.8.5 (Mountain Lion).
I really appreciate any helpful suggestions. Thank you very much!
  • Cayman StudiosCayman Studios Posts: 1,145
    I think the problem is that you do not appear to have Victoria 6 herself, though you have the HD Add-on and Genesis 2 Female. :coolsmirk:
  • Huckleberry41Huckleberry41 Posts: 0
    Jesus! Looks like I missed the forest for the trees!
    Thanks heaps for your help! Problem solved! :-D
